Multiple electrical faults - windows/locks/interior light/light warning buzzer
This is a discussion on Multiple electrical faults - windows/locks/interior light/light warning buzzer within the Octavia I forums, part of the Skoda Model Discussion Area category; I recently had to have minor body repairs to rear 1/4 panel and front wing (both on left). On collection, ...
Old 30-08-2008, 23:36   #1
I recently had to have minor body repairs to rear 1/4 panel and front wing (both on left). On collection, door remote locking, elec windows, interior light, headlight warning buzzer are all in-operable. Tailgate lock works in manual mode but does not synch with doors. Repair shop claim veh was protected from spike during welding. Skoda main dealer ran diagnostics but no fault found. Fuses check out. Any physical disruption would have been to rear left or front left wiring. Any ideas?
Andrew
Andrew58 is offline
Old 30-08-2008, 23:49   #2
VRSPhil's Avatar
Re: Multiple electrical faults - windows/locks/interior light/light warning buzzer
My first port of call would be the convenience unit which is inside the dash, roughly behind the headlight switch. As I understand it, all the functions you list are controlled by this unit.
'54 Passat PD130 Sport... 55mpg
Octavia vRS WRC - Gone but not forgotten!
VRSPhil is offline
Old 31-08-2008, 10:59   #3
ECUless
fordfan's Avatar
Try disconnecting and reconnecting the battery.
fordfan is offline
Old 31-08-2008, 13:41   #4
Thanks for the tip o diconnect/reconnect. Sadly, no improvement. On possibility that the convienience unit has failed, there was a suggestion from the body shop that this was located in the driver door pillar.
Without getting out the blamethrower, is it likely that this failure is related to the pin-welding necessary to pull out the dents? Would convienience unit failure not show on Skoda diagnostics?
Andrew
Andrew58 is offline
Old 31-08-2008, 15:48   #5
Mighty strange coincidence?!
Malc is offline
Old 31-08-2008, 16:47   #6
hussarman's Avatar
If any welding machine that uses electricity has been used it is paramount that the battery should be disconnected first, if gas welding welding is used no need to disconnect the battery.
hussarman is offline
Old 31-08-2008, 16:56   #7
ECUless
fordfan's Avatar
The convenience unit (CU) is located behind the dash close to the back of the light switch. The convenience system will show error codes, though I have come across a couple of cases where they haven't. One was where someone had put the battery on charge for 5 hours (Fabia), unfortunately on the 24V setting, there was a communication problem wth the CU. The second was where there was a problem with the boot lights (Octavia Estate), I think that disconnecting the lights sorted it. Whenever we weld a car at work we put a spike protector across the battery and have so far not had any problems. If a Skoda dealer can't get to the bottom of it, try a specialist auto electrician.
fordfan is offline
Old 03-09-2008, 17:52   #8
Again, thanks for the inputs. It is an Octy Estate and the wiring to the rear cluster had been disconnected. I wonder whether this is the problem.
Andrew
Andrew58 is offline
Tags
elec, fault, issue, multi
Similar Threads
Fabia vRS temp warning light/buzzer alcock555 Fabia I 11 13-03-2008 18:50
Light warning buzzer TIB Favorit, Felicia, Fun and Forman 15 14-09-2007 15:46
Coolant warning light + buzzer tonto kowalski Fabia I 3 22-08-2007 12:55
interior light and warning lights in doors staying on rayzor Fabia I 3 27-05-2007 23:16
Drivers Door Interior Light & Dash light Not Coming On ? jase555 Octavia I 3 30-11-2005 12:35
