My Octavia vRS is misfiring
This is a discussion on My Octavia vRS is misfiring within the Octavia I forums, part of the Skoda Model Discussion Area category; I wonder if anyone can help on a Misfiring issue My 02 octy rs got mapped and i felt it ...
Old 07-04-2006, 22:58   #1
My 02 octy rs got mapped and i felt it was hesitant on ocations afterwards but i
left it for a week as it wasn't really intruding in the enjoyment and it was going back in to get Forge TIP fitted and 4bar fuel reg fitted to compliment the exhaust and filter already fitted and get fueling right for mapp.
the first days were great then it really started to hesitate which i then realised
it was misfiring and it was alot.
anything more than 1/4 throttle passing 2.5-3k revs and bang, it just didn.t like it.
So i thought the plugs may need changed so ngk PFR6Q were fitted, drove it and it was fine,
Next morning bang, it was back again, it just didn't like throttle at all
It freely revs from idle (not moving) but as soon as you drive and push down on the throttle (most noticable 2nd gear and upwards) it just splutters away,
Checked and replaced plugs again just incase they were faulty but no still did it,
No lights coming on and no fault codes are present (checked at 2 diff garages)
Disconnected Maf, the engine spluttered then settled, car still drove with mis,
Maf is 1 year old as replaced already, coil packs were changed at skoda for modified ones as car drove badly and the LIGHT came ON over a year ago.
Mapp was brought back to as near std as it could be with mods and the car drove
near normal (i could put my foot down) but very slight mis was still there somtimes but not all the time.
I checked to see if anything was loose but couln't see anything.
It def is worse when driving from cold, but when mapp activated its vurtually all the time
Has anyone got an idea as i am getting anoyed, tuner thinks it ignition related
even though no codes are present,
Please if anything comes to mind Reply
yellotaxi is offline
Old 08-04-2006, 00:14   #2
Re: my vrs is missing
Vacuum hose? Mine had a similar issue when the hose under the small front engine cover (the one with hundreds of small holes in it) had split. If you can get it to idle badly with the bonne tup have a pull /push on allt he hoses and se eif you can get the engine to idle better by moving them.
Goochie is offline
Old 08-04-2006, 00:23   #3
Ill try that if whether permits sat afternoon
Thanks
Old 08-04-2006, 00:33   #4
For me, it was the rubber hose that runs from the red arrow (in the picture) round the front of the engine.
http://www.philgooch.com/octavia/hose1.jpg
http://www.philgooch.com/octavia/hose2.jpg
Goochie is offline
Old 08-04-2006, 10:44   #5
Re: My Octavia vRS is misfiring
Its absolutly lashing down so i will check these hoses in the dry again just incase
thank for the pictures it makes it so much clearer
Old 08-04-2006, 10:58   #6
splash!!!!
bengie's Avatar
if it changes with temperature maybe its a temperature sensor in the system giving bad reults so causing the car to over fuel or retard the ignition maybe
owner of a skoda octavia 4xvrs3
bengie is offline
Old 08-04-2006, 12:32   #7
Wouldn,t the sensor make a fault code appear
Old 08-04-2006, 15:00   #8
splash!!!!
bengie's Avatar
probably, i was getting the engine light on when cold and it was my coolant temp sensor faulty but it didn't affect running.
other have had different results though i think.
bengie is offline
Old 09-04-2006, 11:33   #9
I have checked the hose and it seems fine
Next
Old 19-04-2006, 21:46   #10
I got alone of a single coil pack and it seemed to work so i got one, still slight hesitation on occation so will see if any other packs are on the way out before looking at other things again BUT
still baffled that no codes or light have been on or logged though
at least i can drive it
Cheers for the help guys
Old 20-04-2006, 23:51   #11
God damn this bloody car
Its back again,
Put a second pack on another cylinder to see if i could see if the slight hesitation would go,
No it got worse,
and for the first time ever the warning light came on,
local garage booked up till mid week next so cant get on diag, so iam ordering another 2 packs and see if the remaining old packs are now to week to function along side the replaced ones.
Do you think this is maybe the case? that the old ones cant keep up with new packs
Your views are more than welcome ppppplease
Old 08-05-2006, 17:18   #12
MY LUCK IS NO LUCK
Just got it back from getting check, the new coil pack is faulty also so
replaced it, and re-set plug gap down from recommended 0.8 to 0.6 and it seems to have worked.
I still feel there is the everso slight hesitation on medium throttle when accelerating somtimes but it cant be pinned to anything so i guess i will drive it for a while till i recoup after the garage bill, and get it on the rollers and
see if shows up at all
Thank for the help and info before guys
Old 08-05-2006, 17:23   #13
splash!!!!
bengie's Avatar
hopefully thats it sorted mate
bengie is offline
