My VRS Did 158 Mph + Fm Intercooler
This is a discussion on My VRS Did 158 Mph + Fm Intercooler within the Octavia I forums, part of the Skoda Model Discussion Area category; Cannot believe my car has managed 158 MPH (if you take a look at my other posts you'll know what ...
Old 05-09-2005, 21:57   #1
Cannot believe my car has managed 158 MPH (if you take a look at my other posts you'll know what ive had done).
The car has just had one if i's final tune ups just rolling road to go to see final power figures and can't wait.
Please see pictures in my gallery or type Front Mounted Intercooler and do a search.
H who performed the work at Ashford Motorsport in Dover Kent,is an expert mechanic, smashing bloke and tells things how they are and likes to do things properly or not at all,instead of selling them things that dont do anything or are not benifical and is passionate about engines and mechanics he hand builds components and regularly builds performance blue print engines for customers using original spec sheets.
He enjoyed working on my car and believes it is the best V.A.G car currently available.He HAND BUILT the FMIC which cost £575 + VAT and it made a massive difference if anyone else is interested call him on 01304 226226 mention 'Stuart' and get it fitted. but please note he takes his time but does an excerlent job well worth the wait believe me.
The car has had a Revo remap, Bailey DV30 dump valve, FMIC, Induction Kit (Viper Type), Full Powerflow Exhaust, Adjusted boost, Timing, Fly by wire Throttle balanced.
You've just been SKODA-taken
hotrodda is offline
Old 05-09-2005, 22:08   #2
Dr Zoidberg's Avatar
158mph according to the speedo or a GPS?
EIther way it's impressive , but there will be quite a difference between the two
Alex
www.drzoidberg.co.uk
Dr Zoidberg is offline
Old 06-09-2005, 08:33   #3
Thats only 11mph faster than mine can go.....according to Skoda
Top job though
lozgti is offline
Old 06-09-2005, 08:37   #4
My 4x4 with Blue Flame zorst, Allard Front Mount, Bailley DV & Jabba map goes way off the clock & will beat standard M3's in a straight line (restricted to 155) so I guess your figure is believable, It might go even faster but its on the rev limiter in top
Speed is an addiction for which thankfully there is no cure
Stuart_J is offline
Old 06-09-2005, 08:41   #5
redbaron's Avatar
and mine did 170+ as did jons / des's / various other too!
________________________________________
Some times I just feel like smiling.
redbaron is offline
Old 06-09-2005, 09:01   #6
faboka vrs's Avatar
Chasing Supra's
John
2004 Skoda Fabia vRS - Xenons - Heated Seats - Cruise Control - Passenger Airbag Deactivation switch - Side Airbags
faboka vrs is offline
Old 06-09-2005, 09:03   #7
Thought I hadn't dreamt it .Which of the above are modded 1.8T's? All of them?
VAG group engines allegedly best for tuning as the parts are designed for much greater stresses than is normally put on them..according to autocar.Probably not wrong if you can wring 170 out of them(if any of the original parts remain that is )
lozgti is offline
Old 06-09-2005, 09:03   #8
DGW
BRISKODA Staff
DGW's Avatar
Is that 158 indicated or verified by GPS or other reliable means?
Denis
DGW is offline
Old 06-09-2005, 09:57   #9
Joel_vRS's Avatar
interesting pics of the FMIC... i have to ask if the intercooler was hand bulit why go for that style why not go for the forge style with the In and out at one side? i was under the impression that long lengths of pipes coudl lead to loss of boost pressure.. in a similar way you get voltage drop through longs bits of wire...
i will note the number if my plans dont work out i will give him a call and see what he can do..
Thanks
Joel
Everyday car: Pimp Black Skoda Octavia VRS, 230bhp, 250lb custom remap, blueflame stainless exhaust, lowered, Hyperboost Dump Valve, ABD tip. 1/4mile in 14.99 secs
Project Car: Vintage Mk2 Golf, to be turned in to a 1/4 mile beast, 1.8T 20v engine conversion! Watch this space!!!!
Joel_vRS is offline
Old 06-09-2005, 11:04   #10
BRISKODA Staff
SkodiRS's Avatar
Thanks
Joel
Apparently it's better to have in and out at opposite side with inlet at top and outlet at bottom.
However, you then have to take into consideration the piping to return the turbo inlet...all to do with flow and pressure loss...I think.
Check out this following link for FMIC design.....interesting reading.
Intercoolers
Adrian.
SkodiRS is offline
Old 06-09-2005, 11:10   #11
Joel_vRS's Avatar
yes yes i have read that before... and am basing my FMIC top secret project on the therory of that website... i was questioning about the in and out in this example because of how the pipes are run... if the pipes were run diffrenty i wouldnt question it..
Joel
Joel_vRS is offline
Old 06-09-2005, 12:23   #12
A colleague of mine has had 158 (on the clock) out of his std Oct vRS, but it was down a steep hill!!!! on his private road!!!
You've been Skoda'taken!
delroy is offline
Old 06-09-2005, 12:58   #13
Joel
Mine was built by Allards, uses the opposite corner theory but re routes one over the top of the engine bay, works incredibly well, This Piccie hosted by Dennis (thanks again) shows the idea
http://www.briskoda.net/gallery/show...s&searchid=495
Stuart_J is offline
Old 06-09-2005, 13:04   #14
Mil
Mil's Avatar
Congrats dude. I'm sure you did and authentic 155mph + , but majority in here won't believe it
Milton Kyvernitis
Private Government
Mil is offline
Old 06-09-2005, 13:24   #15
RICHARD
Fabia 12v's Avatar
all on private roads i hope
First Car: Skoda Fabia MK1 1.2 12v Comfort
Replaced with: Volkswagen Golf MK4 GT 1.9TDI
Replaced with: Seat Ibiza MK4 Sport 1.9TDI
Replaced with: Volkswagen Polo MK6 Ltd. Edition Sport 1.4 16v
Fabia 12v is offline
Old 06-09-2005, 20:25   #16
Well glad to hear some people are also getting the most from their VRS, the speed was shown on a lap top within the car so was accurate, the most important thing though is it's the fastest car I have owned and the speed read out was real. I did the mods for ME no one else and more importantly did not do it to 'keep up with the jones's' thanks for people replys nice to hear from you all, but remember
''People who talk talk,
people who are doing it keep quiet and over take''.
hotrodda is offline
Old 06-09-2005, 20:33   #17
Worthless loser
drm_jones's Avatar
Doing some very rough calculations - 158mph true speed is certainly possible with around 230bhp - a power figure which looks about right given the modifications to the car .
David
2002 Black Magic Octavia V/RS
drm_jones is offline
Old 06-09-2005, 20:45   #18
Mongreller
devonutopia's Avatar
Images: 5
Stu! SNAP! Although I noticed your turbo hoses actually route through to the engine. Mine's actually a solid welded up pipe through to the engine bay, which is why the angle grinder was needed so much.
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 06-09-2005, 20:56   #19
Top job. Glad your happy with your mods to date you'll soon have the bug big style and have it up at 300bhp, by the way on Club SE a KO4 is up for grabs in the for sale section.
Also glad you didn't post this too near the Fabia section as WW3 would have been unleashed.
Glider is offline
Old 11-09-2005, 09:16   #20
Meaning what?
hotrodda is offline
Old 11-09-2005, 10:53   #21
Escorted Estate
For the sake of sanity of you, me and everyone else, don't even go there There have been some moments where certain claims where questioned to a point where it got a bit long in the tooth, whether a claim was believed or not
I'll join in on the: nice job however
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
Old 11-09-2005, 12:10   #22
Here
http://www.briskoda.net/forums/t3421...-vs-xxxxx.html
Glider is offline
Similar Threads
Introduction to the Fabia ColinD Fabia I 17 17-12-2007 14:11
My '05 vRS Fab - Initial Thoughts subvertbeats Fabia I 32 17-08-2005 10:57
National Briskoda Trackday delcac Shows 410 12-03-2004 15:21
