This is a discussion on n249 help within the Octavia I forums, part of the Skoda Model Discussion Area category; does any one have the part number for the n249 valve?...
| Briskodian Join Date: Apr 2008
| n249 help does any one have the part number for the n249 valve? |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
| Re: n249 help N249 - 078 906 283 A
__________________ Regards Martin Turbo back blueflame exhaust |
| Re: n249 help cheers martin. i changed one valve yesterday and found a split pipe aswell but i didnt change the valve that is held in with 2 philips screws i take it this is the n249 then. |
| Re: n249 help Not sure tbh as i have never changed one but i'm sure someone on here knows.
Images: 2 Thanks: 22
| Re: n249 help Two phillips screws? Sounds like the boost pressure sensor to me, where abouts you looking? What car is it on?
| Briskodian Join Date: Feb 2006 Location: Somerset
| Re: n249 help Don't remember any screws when replacing the N249.
__________________ 2001 Skoda Octavia vRS Blueflame Catback Exhaust, CAI, Forge TIP, Forge 007 Valve, N75j, Weitec Dampers and Springs, WRC Spoiler, WRC Graphics. |
| Re: n249 help its on a vrs 52 plate im looking under the plate at front of engine there is 2 valves there one held in by rubber mount the other by 2 screws. i changed the 1 with rubber mount car still hesitating on boost and running the same as before i changed it. so wondering if n249 is the one at end near the throttle. |
| Re: n249 help Yeah you are right, are you sure its not the DV?
| Re: n249 help Yeah the one held in with the rubber mounts is the N249
| | #10 |
| Briskodian Join Date: May 2004
| Re: n249 help I'm going to try one of these for the 17705 fault |
| | #11 |
| Re: n249 help im running a bailey dump valve before the throttle body dv seams fine inside but car is not pulling well and dump valve pressure sound does not blow off very loud anymore. wot is the other valve next to the n249 and wot doe that do? |
| | #12 | |
| Briskodian Join Date: Sep 2007 Location: England
| Re: n249 help Quote:
It uses the vacuum system to open the combination valve, so that's why it's there. I wouldn't bother replacing it, as I can't see how it would cause your symptoms. But if you do try it, let us know if it does anything!! Sounds like you've done the N249 (with the rubber mounting). After I changed mine, it fixed my sudden boost loss when pulling away problem. But I still have the 17705 code, but with no bad side effects.... New N75 and intercooler to intake hose next.......
__________________ Diamond Silver '02 Octavia vRS hatch | |
| N249 Mechanical Malfunction | Harry_vRS | Octavia II | 28 | 26-03-2008 20:39 |
| N249 location diagram please.... | Steevie Wonder | Octavia I | 2 | 25-08-2007 09:01 |
| Disabling N249 valve | sbrauns | Octavia I | 0 | 07-06-2005 00:29 |
