N75J fitted
This is a discussion on N75J fitted within the Octavia I forums, part of the Skoda Model Discussion Area category; and the car is worse. still hesitates under part acceleration and is now venting off boost under part load at ...
Old 19-01-2008, 19:27   #1
N75J fitted
still hesitates under part acceleration and is now venting off boost under part load at 4500rpm, which is odd as its not at WOT.
Regards,
Mike
Proud owner of a Remapped Red Octavia vRS
Never argue with an idiot - they will only beat you with experience.
Angry Dog is offline
Old 19-01-2008, 19:39   #2
Need more power
martziniuk's Avatar
Re: N75J fitted
Its probally fitted the wrong way.
J vesion goes on with the connector facing the bulkhead.
The f and h version go on the normal way,the j goes on the other way.
Regards Martin
Turbo back blueflame exhaust ,Forge 007p Dump valve,Prosport boost gauge, Autobahn88 TIP, Ecu Evolution Remap, FMIC
martziniuk is offline
Old 19-01-2008, 20:15   #3
Re: N75J fitted
my initial thoughts were that it did! ta mart, full power restored, but problem still there
Regards,
Mike
Old 19-01-2008, 20:23   #4
Fezboy's Avatar
Re: N75J fitted
Mike is the car showing any error codes?
What do you mean venting off boost?
Mine sort of does this now and again around 3K foot half down and I get psst psst psst psst? It's more like pulsing?
I don't get any hesitation(Well none that I notice)
Octavia VRs ***SOLD***
The futures somkey! The futures diesel
Fezboy is offline
Old 19-01-2008, 20:39   #5
Re: N75J fitted
I havent got any codes that I can see.
the venting of boost was it dumping all the boost lol - its back to normal now though.
my hesitation / judder happens under acceleration on part load - in the transient stages. under WOT my car is great until 6k rpm in 3rd when it missfires but you can drive through it.
Regards,
Mike
Old 19-01-2008, 20:46   #6
splash!!!!
bengie's Avatar
Re: N75J fitted
a lot of cars do it mike, its a common thing that i don't think you'll fix.
i know mine did it on a jabba map.
owner of a skoda octavia 4xvrs3
bengie is offline
Old 19-01-2008, 20:49   #7
ethos's Avatar
Re: N75J fitted
Mine sounds like it does the same sort of thing.
As for the J n75, from what i've read on these forums some cars love it and some don't get along with it... guessing it depends on what map etc.. etc... you have.
ethos is offline
Old 19-01-2008, 20:54   #8
Re: N75J fitted
I dont recall anyone elses missfiring at 6k rpm in 3rd though?
Regards,
Mike
Old 19-01-2008, 21:19   #9
ethos's Avatar
Re: N75J fitted
Nope, I haven't seen this....
Coilpacks?
ethos is offline
Old 19-01-2008, 21:36   #10
cowper3010's Avatar
Re: N75J fitted
im in a learning mood tonight lol what is n75j?
cowper3010 is offline
Old 19-01-2008, 21:41   #11
Fezboy's Avatar
Re: N75J fitted
Coilpacks?
That should throw up a code though!
I was thinking the same
Coil pack/plugs/plug gap?
Fezboy is offline
Old 19-01-2008, 22:04   #12
ethos's Avatar
Re: N75J fitted
Why did you go for the J over the "race H" btw?
VAG 1.8T - N75 H Control N75H Race Valve - Free P&P on eBay, also Engine Tuning Parts, Performance Tuning Parts, Car Tuning Styling, Cars, Parts Vehicles (end time 09-Feb-08 20:02:59 GMT)
ethos is offline
Old 20-01-2008, 00:24   #13
splash!!!!
bengie's Avatar
Re: N75J fitted
i was meaning the part throttle hesitation not the misfire
it might sound like a silly question but what exactly happens during the misfire? is it simply a slight misfire involving a little noise and judder or something other than that?
the more info you give us the more we can try and help you
bengie is offline
Old 20-01-2008, 00:48   #14
Need more power
martziniuk's Avatar
Re: N75J fitted
It should not misfire around 6k. This defo sounds like a plug/coil problem,has it happened since you regapped them?
You will just have to wait until your new plugs arrive.
Mike in answer to your previous pm. Your problem is different to mine as mine used to hesitate on full throttle only, it was great on part throttle.
Regards Martin
Old 20-01-2008, 04:54   #15
Rob_OctaviavRS's Avatar
Re: N75J fitted
This N75H on ebay thats been mentioned, is it any good? thinking of giving it a go as its on my parts to change list, cheers.
2.3 Litres with 28PSi boost = Toodle Pip!
Harmon Kardon AS3 Audio, Bi-Xenons, Heated Aero Leather, 280BHP + 400NM
Rob_OctaviavRS is offline
Old 20-01-2008, 11:15   #16
Re: N75J fitted
I got the J as im just eliminating possible faults.
Regards,
Mike
Old 20-01-2008, 14:30   #17
Silver bullet
Steevie Wonder's Avatar
Re: N75J fitted
Why don't you just fit the proper one for the car......
N75 'F' VAG part no. 058-906-283-F
Sounds like your coil packs are shafted too.
The silver bulletJabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.
Steevie Wonder is offline
Old 20-01-2008, 21:24   #18
Re: N75J fitted
If the coil packs were shafted, the car would miss under WOT when the car is under more load in all gears, rather than just at one rev point.
the missfire doesnt occur all the time either.
Regards,
Mike
Old 21-01-2008, 10:19   #19
Here's Johnny !
Johnny50's Avatar
Re: N75J fitted
Mine is on a Jabba Custom map and does that too.
Johnny50 is offline
Old 21-01-2008, 10:28   #20
RichB86's Avatar
Re: N75J fitted
Whereabouts is the N75 located? could someone post a picture of where it is please? because i alway thought it was the one on the top of the engine but thats another N something isnt it?
Must Go Faster
RichB86 is offline
Old 21-01-2008, 11:25   #21
SMOGUS MAXIMUS
Beretta's Avatar
Re: N75J fitted
The N75 "IS" on top of the engine, just to the right of the dump valve.
Skoda performance was "IMPOSSIBLE", now its Japanese and 177 bhp and 295 lb ft torque of SMOG.
Gerry
"HONI SOIT QUI MAL Y PENSE"
Beretta is offline
The Following User Says Thank You to Beretta For This Useful Post:
RichB86 (21-01-2008)
Old 21-01-2008, 14:26   #22
RichB86's Avatar
Re: N75J fitted
ahh well that helps! been putting it off as i couldnt find it as didnt think it was that one.
Thankyou
Must Go Faster
RichB86 is offline
Old 21-01-2008, 19:37   #23
splash!!!!
bengie's Avatar
Re: N75J fitted
your thinking of the N249 valve i believe
bengie is offline
Similar Threads
Have you fitted....? youngsyd ICE, Security and Insurance 17 19-02-2008 06:06
Chipped Octy vRS 'lumpy' around 3-4K rpms - Need N75J??? sixman9 Octavia I 3 03-10-2005 22:52
N75J Waste Gate Solenoid MATT INTRODUCE YOURSELF! First time visitors, say hello here. 3 20-05-2004 14:09
