This is a discussion on Negative Boost within the Octavia I forums, part of the Skoda Model Discussion Area category; I have just fitted a boost gauge for the first time and I just wanted to check that when I ...
| Briskodian Join Date: Jun 2007 Location: Derby / Exeter
| Negative Boost I have just fitted a boost gauge for the first time and I just wanted to check that when I am driving at low revs (Out of the turbo) the gauge should be reading negative? When the car is in the Turbo the boost pressure is positive as expected. (Will have a look and see what sort of boost it is hitting tomorrow!!)
__________________ Current Mods - Milltek Exhaust, Forge Recirculating DV, Pipercross panel filter, Fast rd Pads and Discs, Coilover kit, Front mounted intercooler, 18" Alloys, Forge TIP, a few stickers and plenty of ICE Planned Mods - Highflow Cat, Custom Re-map |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
| Re: Negative Boost In a nutshell ................Yes If you have a re-map you should be around 15psi plus, then dropping back iirc |
| Briskodian Join Date: Jul 2006 Location: Newport/Preston
| Re: Negative Boost No boost should be showing as 0 surely? Negative is a vacuum? |
| Re: Negative Boost Zero is atmospheric pressure anything above is boost or something like that................. I can't remember right now to be honest. Some one how knows will be along to explain I'm sure ![]() ![]() |
| Ta moko! Join Date: Jun 2004 Location: Aotearoa - land of the long white cloud
| Re: Negative Boost It should defintely be showing vacuum (negative) when idling or off boost. But I don't know why!
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook |
| Re: Negative Boost Rob we've been here long enough to know why really. Should we be ashamed of ourselves............You especially ![]() ![]() |
| The Following User Says Thank You to fatty5000 For This Useful Post: | RobClubley (11-02-2008) |
| | #7 | |
| Briskodian Join Date: Sep 2003
| Re: Negative Boost Quote:
__________________ Octavia 4x4 | |
| | #8 | |
True!
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook | |
| Briskodian Join Date: Apr 2006 Location: Sheffield
| Re: Negative Boost Rob cant be held responsible for not knowing why as he has the big responsibility for hosting the picture that has shown every one where to plumb in the T piece ![]() |
| | #10 |
| Re: Negative Boost You're all correct; off-turbo, a 2-way boost gauge will read below atmospheric pressure (negative). This is because the air is flowing through a pipe, and when this happens, its pressure does drop as a result. If you want a better expn, run a web search for "gas dynamics". |
| | #11 |
| Why me ? Join Date: Oct 2005 Location: North Yorkshire
| Re: Negative Boost
__________________ ![]() ![]() '05 Audi A4 2.0 Tdi SE - no mods until the warrenty expires '00 Audi A4 2.8 Quattro - Gone.... (bleeding money pit )Audi A4 2.6 Avant (Breaking - Check out http://shop.ebay.co.uk/merchant/auroan) |
| The Following User Says Thank You to auroan For This Useful Post: | KenONeill (11-02-2008) |
| | #12 | ||
![]() ![]() Quote: | ||
| | #13 |
| Re: Negative Boost Knowing that it happens, and that the deeper the depression, the higher the throttle setting (off turbo on naturally aspirated cars only) is about all you need for practical purposes. |
| | #14 | |
Even though sometimes I have no idea what your on about ![]() | |
| | #15 |
| Re: Negative Boost Just taken her out for a blast and I am seeing between 0.6 - 0.7bar of boost pressure...... Is this about right for an un-mapped car? Also a big thanks to all of you for the info to allow me to fit it! (Especially Robs pictures!!)
| | #16 | |
| The Following User Says Thank You to RobClubley For This Useful Post: | Meggsy (12-02-2008) |
| | #17 |
| Re: Negative Boost Also getting chatter from the Boost gauge !? Is this normal ? Can I get rid of it?
| | #18 |
| Re: Negative Boost yup, you'll need a little filter to smooth the airflow on the pipe work connecting the boost gauge
| | #19 |
| Re: Negative Boost Like a fuel filter?
| | #20 |
| Re: Negative Boost yeah, but a very small one. The other way is to use a small screw clamp to squash the gauge pipework a little.
| The Following User Says Thank You to auroan For This Useful Post: | Meggsy (12-02-2008) |
| | #22 | |
| Silver bullet Join Date: May 2003 Location: Planet Earth......
As for negative boost, mine used to be around 1 bar or -15psi when running the standard turbo on tickover/off boost. Hope this helps. Steve ![]()
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() | |
| The Following User Says Thank You to Steevie Wonder For This Useful Post: | Meggsy (12-02-2008) |
| | #23 |
| Briskodian Join Date: Jun 2006 Location: Melksham
| Re: Negative Boost |
