This is a discussion on Neuspeed Rear ARB within the Octavia I forums, part of the Skoda Model Discussion Area category; Simple question, is the 28mm rear anti roll bar (which is available for the octy) likely to cause rear end ...
| Briskodian Join Date: Jul 2006 Location: Cleveland
| Neuspeed Rear ARB Simple question, is the 28mm rear anti roll bar (which is available for the octy) likely to cause rear end traction issues under hard cornering? |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Re: Neuspeed Rear ARB If you set it to the stiffest setting you can get oversteer. I had mine on the middle setting and had no problems.
__________________ Adrian. |
| The Following User Says Thank You to SkodiRS For This Useful Post: | VRSPhil (29-05-2007) |
| Briskodian Join Date: Sep 2006 Location: Ilford, Essex
| Re: Neuspeed Rear ARB mine is in the middle setting without any problems. tightens the rear end up nicely!!!
__________________ ![]() Now that will teach him to mess with a VRS!! |
