This is a discussion on New gauge within the Octavia I forums, part of the Skoda Model Discussion Area category; Here's my boost gauge . Got the electrics plumed in, just waiting for a friend to help with linking into ...
| Briskodian Join Date: Mar 2007 Location: Cardiff
| Here's my boost gauge . Got the electrics plumed in, just waiting for a friend to help with linking into a vaccum pipe. Doesn't look too bad - what does everyone think?A close up. ![]() As the driver would see it ![]()
__________________ ![]() Modified Airbox - Boost Gauge To Do:- Rear A.R.B, 4 x Toyo T-1R, Polyflex Bushes, Green Panel Filter, Forge D.V Last edited by jon.erasmus; 29-05-2007 at 19:34. |
| Briskodian Join Date: Jan 2007 Location: Dublin
| nice what make is it???????
__________________ Yes Its A Skoda,Deal With It!Now Gone Golf 1.9 TDi Sleeper Power,Enough said! |
| Briskodian Join Date: Jun 2006 Location: Melksham
| Night time ![]()
__________________ ![]() Modified Airbox - Boost Gauge To Do:- Rear A.R.B, 4 x Toyo T-1R, Polyflex Bushes, Green Panel Filter, Forge D.V |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
| How did you stick it to the dash? |
| Cut and drilled a 90 degree piece of metal to fit and stuck it down with velcro, didnt want to start drilling holes in my pride and joy!!
| I am the Law! Join Date: Oct 2006 Location: Scottish Borders
| So when are you fitting a BOOST gauge? Sorry couldn't resist,very nice installation though, I want one now! Cheers, Steve
__________________ ![]() ![]() ![]() NO PLAN SURVIVES CONTACT WITH REALITY!! |
| Haha, edited now. Had a few too many when i wrote this i think.lol
| | #10 |
| yea .5 bar........sorry the logo was a Give away!!!
| | #11 |
| thought it was .7 bar
| | #12 |
| standard 180bhp vRS makes approx. 0.7bar boost |
| | #13 |
| really??? learn somthing new Every day!
| | #14 |
| Briskodian Join Date: Dec 2004 Location: Gloucester
| They peak at 10 psi and hold 7, by the way I have an Autometer 30psi (52mm) boost gauge up for grabs if anyones interested £40 inc postage. CheeRS Andy |
| | #15 |
| well mine is standard and holds between 0.65 and 0.7 bar (9.5-10psi) depending on conditions, air temperature etc. I've not taken much notice of peak values. These are from readings of live data from the management system, so not based on a shonky boost gauge that could be reading wrong.. ![]() |
| | #16 |
| Thought boost gauges were more accurate then vag com for readings
| | #17 |
| Briskodian Join Date: Sep 2006 Location: Ilford, Essex
| well mine peaks up to about 10 psi and holds about 7-8 psi. depending what mood the car is in!!!! as for accuracy. the gauge is only as accurate as it was set up during manufacture. if nothing else the dial behind the needle could have twisted around slightly giving all sorts of readings. all they do is give you an idea what its boosting at. do tuners watch the gauge that you have plumbed. i dont think so!!!
__________________ ![]() Now that will teach him to mess with a VRS!! |
