New timing belt + petrol pump?
This is a discussion on New timing belt + petrol pump? within the Octavia I forums, part of the Skoda Model Discussion Area category; I have a 1999 1.8 Octavia auto. I have booked to have my timing belt, tensioner and damper replaced at ...
Old 31-12-2005, 16:31   #1
I have booked to have my timing belt, tensioner and damper replaced at 60,000
miles. My dealers said that they thought it unnecessary to have the petrol pump changed. Is it wiser to have the pump replaced at the same time?
I have been advised that the cost of the service and belt change will be £450. Does that sound reasonable?
BrownieXP.
BrownieXP is offline
Old 31-12-2005, 17:44   #2
Re: New timing belt + petrol pump?
No need to replace the petrol pump dont you mean the water pump as i had mine replaced when i had my cambelt replaced as it involves the same work.
I paid 290 for cambelt and water pump changed so 160 sounds about right for a good full service.
Burnsy is offline
Old 31-12-2005, 17:46   #3
Txt Spk Police
VRStu's Avatar
I think it would be water pump too.
Stu
VRStu is offline
Old 31-12-2005, 18:32   #4
skodaw's Avatar
Location: This area is under construction - please call back later :)
Yup Waterpump and definately worth doing at the same time.
Petrol pump should last for quite a bit longer -- would not expect to replace that untill well over 100k
Dave
'05 Silver Fabia vRS
skodaw is offline
Old 06-01-2006, 12:11   #5
Thumbs up Re: New timing belt + petrol pump?
Thanks for all your inputs!
Am getting an independent local VAG garage to do the job for me. Cambelt + tensioners £250; service £160.
Was advised not to replace the water pump as replacement pump still has a plastic impeller, the same as my old one.
BrownieXP
Old 07-01-2006, 10:07   #6
Txt Spk Police
VRStu's Avatar
I'm not an Octy expert but as far as I understand that's the whole reason to change it, they wear out and the cost of the components is minimal compared to the labour costs involved should it fail. It's preventative maintenace while the engine is stripped down.
Stu
VRStu is offline
Old 07-01-2006, 10:48   #7
skodaw's Avatar
Would STRONGLY recomend replacement of waterpump
If the pump fails - you will be looking at the same amount of labour all over again - and I suspect any garage worth dealing with would also want to replace the belt again - as you can't rule out the belt being damaged or contaminated with coolant.
If your worried about the plastic impeller -- try Eurocarparts -- I know they have pumps that have a metal impeller.
Dave
skodaw is offline
Old 07-01-2006, 11:00   #8
skodaw's Avatar
BrownieXP
If it's the garage that are doing thw work that have advised this - I suggest you find another garage, they obviously don't have your best interests at heart - they would obviously love you to have the waterpump done at some other time at greater cost!!
Dave
skodaw is offline
Old 07-01-2006, 11:16   #9
Txt Spk Police
VRStu's Avatar
I agree. If they are a VAG specialist then I would suggest that they ought to know about the costs involved.
Stu
VRStu is offline
Old 08-01-2006, 13:38   #10
Mil
Mil's Avatar
It's the water pump you're talkin' about. I'm in the process of just getting that service done to my Fabia now I've hit 90,000kms, i.e., water pump, tensioners and belts.
Milton Kyvernitis
Private Government
Mil is offline
Old 08-01-2006, 20:27   #11
After reading all your further inputs, am now going to have the water pump replaced at the same time! Thanks again!
Better safe than sorry!
Brownie XP
Old 08-01-2006, 20:51   #12
skodaw's Avatar
Brownie XP
That's definately the best route to take,the additional cost is neglible considering the possible benefit.
Dave
skodaw is offline
Old 08-01-2006, 20:52   #13
DGW
BRISKODA Staff
DGW's Avatar
A friend of mine had a water pump fail not long after a timing belt change (the 2 events were unrelated). The ensuing hefty repair bill included replacing the timing belt again since that is sound practice.
Denis
DGW is offline
Similar Threads
RS timing belt gone after 20k miles !!! Flanno Octavia I 21 08-07-2005 08:34
Petrol Pump attendant surprise! plumsoul Off Topic and Chit Chat 0 18-04-2005 22:27
Timing Belt Cobra General Car Chat 9 23-02-2005 23:47
Timing belt? Camshaft belt? Alternator Belt? zhangzheng Maintenance & Performance 1 29-10-2004 09:16
