This is a discussion on Newbie (advice needed) within the Octavia I forums, part of the Skoda Model Discussion Area category; No Octavia yet, ive been looking to sell my current scooby and get something a bit cheaper to reduce my ...
| Briskodian Join Date: Jan 2005 Location: Cambridgeshire
| Newbie (advice needed) No Octavia yet, ive been looking to sell my current scooby and get something a bit cheaper to reduce my car loan but a bit quicker. Im looking for a 1.8T probably in elegance spec, ive been looking for them online ive found a lot of slxi and glxi models is this an earlier model desegnation? can someone give me a hand decoding this? also i live in the peterbough area can someone recomend a good place for servicing, i dont want to have to use Wings as paul wing is an absolute c*nt and it will be a cold day in hell before i give him any money! anything else i should be looking out for on the 1.8t models? |
| | #2 | |
| Briskodian Join Date: Nov 2004 Location: Beverley, East Yorkshire
| Quote:
Mine is only just a year old so can't really comment on any faults, it has been ok so far but i am sure there will be common problems. One thing i have heard of is coil pack failure but this should be rectified under the warranty anyway. | |
| Briskodian Join Date: Oct 2003 Location: shropshire
| jabba sport are near peterborough,not sure if they do servicing but they'll tweek it to around 200+ bhp for you,get em to change the oil while they do it. well recomended on here
__________________ louder than war |
| I use WJH Motors. The main premises are in Bedford but you can also get your car serviced at Riseley if you ask nicely.
| | #5 | |
| Discordian Join Date: Jan 2003 Location: Newport, Newport - so good the Post Office named it twice
| Quote:
The SLXi is roughly equivalent to Elegance trim, but IIRC it has leather upholstery instead of cloth (Nick - is that right?). The older 1.8T engine is slightly different, as well; it doesn't have a drive-by-wire throttle, so it can't be remapped to quite the same power levels as the later engine. On the other hand, this isn't important unless you want to tune it to within an inch of its life. Generally, the 1.8T models are pretty robust. You'll probably have a better chance of finding a tidy one (pre- or post-facelift) than the lower-spec models - which might have been used as taxis ![]()
__________________ Mike | |
| Right looking at the insurance again it looks as though the RS is within my reach. For my budget though 6k ill be looking at a 100k or there abouts model, now this doesnt bother me to much since i know most cars will be more than able to manage this (if theyve been well looked after) but what sort of things should have be done by this point in the cars life and what will i be looking at that might need to be done soon? |
| Briskodian Join Date: Jun 2003
| clutch and box is the weak point... especially if its been tuned. RS for 6k is not ghoing to be easy... but it is worth it. Watch out for imported irish spec cars with lower spec.. (smaller wheels, no cd changer etc)
__________________ ________________________________________ Some times I just feel like smiling. |
Images: 2 Thanks: 22
| Usually by around 100k it will or should of had Cambelt and tensioner Clutch Other than that there aint really that much thats costly. Turbo's are also known to give up (but not all, its a bit of a lottery) usual checks for smoke and odd noises on boost apply. Good luck ![]()
| | #9 | |
| Briskodian Join Date: Jan 2003 Location: Winchester
| Quote:
__________________ Speed is an addiction for which thankfully there is no cure | |
| | #10 |
| Lol the thing is im probably moving a lot closer to my works so it wont get my than 5k a year on it if it had been a lower spec 1.8t i would be tuning it but with an RS it will be staying completely standard. What other tell tale signs will i be looking at on an irish spec model? |
| | #11 |
| 4x4 will be cheaper, a good map, say Jabba costs lessthan £500, also cheaper to insure
| | #12 | |
| Quote:
it will bit a spirited driver will want to change suspension and wheels to get the best from it... ![]()
__________________ ________________________________________ Some times I just feel like smiling. | |
| | #13 |
| Indeed i was initially put off by the higher than standard suspension on the 4X4 |
| | #14 |
| you done your research... they do sit higher to afford more ground clearence.... depends whether your miles covered includes rough / poor surface or is mainly motorway?
| | #15 |
| no rough stuff, peterborough is a series of dual carrigeways joined by lots of roundabouts, i was leaning towards the RS because i was presuming its probably got a more sporty suspension setup Last edited by Willod; 30-01-2005 at 14:44. |
| | #16 |
| 200 laps....... Join Date: Dec 2003 Location: Essex
| it has but you could put lowered suspension on it and it would handle the same as the vRS. if i'd have know what i know now i'd have been very tempted to go the 4x4 route and spend the saved money on a few wise mods.
__________________ Alex Skoda Octavia vRS-Awaiting Mike at Impossible to sort out STILL RenaultSport Megane R26 Ultra Blue Number 21 Honda CBR600Fi |
| newbie needs advice | Luke | Fabia I | 26 | 17-10-2004 15:18 |
| Newbie wanting TDI 100bhp advice | badgerman | INTRODUCE YOURSELF! First time visitors, say hello here. | 6 | 11-10-2004 17:54 |
| Newbie here. Buying advice please | steveo | General Car Chat | 11 | 14-04-2004 18:48 |
| Urgent Advice Needed, Please Read Help!!! | mannyo | Off Topic and Chit Chat | 53 | 01-11-2003 20:31 |
| Picking Up New Vrs On Friday Advice Needed Please. | leon | General Car Chat | 42 | 04-06-2003 19:37 |
