No Power 90 tdi
This is a discussion on No Power 90 tdi within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi everyone havn't been on for a while, anyhow. Octavia 1.9 tdi 90bhp, runs as if there's no turbo, lost ...
Old 07-11-2007, 17:56   #1
Unhappy No Power 90 tdi
Octavia 1.9 tdi 90bhp, runs as if there's no turbo, lost power over the day, the car is a taxi base car, it's on a 53 plate and done 160000 miles, it had a new turbo fitted in July this year.
I am wondering if it is the airflow meter, i've tryed one from another car that i know works (110 tdi) but it made no difference, is this because the ecu needs resetting to the new airflow meter and the fault clearing, there are no flshing codes displayed on the dash, it's as if it is running in limp mode.
If you take off the intercooler pipe from the egr valve you can feel the turbo blow through at a fair rate, but there is no load when free reving this is why i thought maybe airflow.
Any ideas would be most appreciated
Keith
boginhood is offline
Old 07-11-2007, 18:35   #2
gcr31463's Avatar
Re: No Power 90 tdi
I'd think your right suspecting the MAF, had mine done under warranty at main dealer, not sure if they had to reset the ECU or fault memory though.
http://www.briskoda.net/forums/octav...ssing-s/91030/
http://www.briskoda.net/forums/techn...?highlight=maf
do these links help?
cheers ... darren
Octy II 2.0 (?Turbo?)DI Plus some RWD stuff.
Next trip from Scunthorpe & Doncaster
http://briskoda.net/midlands-skoda-m...26-oct/125071/
gcr31463 is offline
Old 08-11-2007, 17:03   #3
Re: No Power 90 tdi
Thanks Darren, it will occasionally boost up over 3000 rpm, but other than that it seems turbo less, its going on the machine tomorrow to see whats what, i'll post the out come when i know more.
Cheers Keith.
Old 08-11-2007, 17:13   #4
Re: No Power 90 tdi
Hi There, Mine had a similar problem a while back and it turned out to be a blocked fuel filter. As soon as i changed it the car went like a rocket again. Hope this helps.
prb78 is offline
Old 09-11-2007, 19:46   #5
Question Re: No Power 90 tdi
Diagnostic shows that the Fuel Pump Injection Timing Valve is at fault.
Does anyone know if this is a bolt off and on repair
Old 09-11-2007, 23:23   #6
daverapid's Avatar
Re: No Power 90 tdi
I would get your cam belt checked A.S.A.P. in case it has slipped a tooth before it does any proper damage.
David McKinney
TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN
www.skoda-owners-club.org.uk
daverapid is offline
Old 09-11-2007, 23:33   #7
Re: No Power 90 tdi
Changed cambelt and tensioners, think old one may have slipped slightly and caused the problem
Old 09-11-2007, 23:48   #8
daverapid's Avatar
Re: No Power 90 tdi
So, is it OK now with the new belt fitted and timed correctly?
David McKinney
Old 10-11-2007, 09:35   #9
Re: No Power 90 tdi
The car lost power over the day, the driver said it was flat as if no turbo but there was a whirring noise coming from the belts, was concerned there may be a tensioner failer on the way so took to cam belt specalist.
It was stripped down and you could see marks on the rollers and tensioner as if some slipping had occured, i was then informed by the driver that occasionally when starting from cold the engine would judder violently and not start then on the second attempt would be ok.
The elongated bolt holes on the pump where against their stops to the right
Everything was stripped down, the tensioner if you shook it rattled as if the bearing was falling to bits
Complete new kit was fitted and re-timed. Still flat but at least safe.
Diagnostic showed Injection Pump Timing Solenoid Valve which we think was damaged due to the belt slipping slightley, anyhow valve is on order from skoda and was wondering if they are easy to fit, will post the results.
Thanks Keith.
Similar Threads
Lost Power!! 1.9 tdi prb78 Octavia I 4 16-06-2007 19:48
TDI Power tefal1 General Car Chat 12 28-02-2007 23:26
tdi power loss zebedee Octavia I 3 20-03-2006 11:41
19 tdi power loss.... escy Octavia I 4 27-06-2005 22:15
PD TDI Power? LloydVRs General Car Chat 15 06-04-2004 16:58
