This is a discussion on Noise after starting car within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi My 54 plate vrs makes a horrible noise after starting, like the exhaust is blowing badly, but after a ...
| Briskodian Join Date: Apr 2006 Location: Fife
| Noise after starting car Hi My 54 plate vrs makes a horrible noise after starting, like the exhaust is blowing badly, but after a few minutes this noise stops and the car is totally quiet. Think the noise is coming from the front of the car..... Any ideas? Graeme |
| Re: Noise after starting car Could that be the charcoal filter? I don't have one, so only making a guess, but I think it makes a ticking sort of noise, so maybe not the exhaust blowing type of sound. Or maybe next door's cat was under the car :-) |
| Briskodian Join Date: Aug 2006 Location: East Lothian
| Re: Noise after starting car Its the secondary air pump,this blows excess air into the inlet manifold, and runs for about 2 mins after starting. The purpose of which is to heat the cat up to working temp quickly. It is quite normal to hear a noiseduring this period. |
| Re: Noise after starting car The secondary air pump is barely audible on my car. If the noise is loud, it could be an indication that the pump is faulty.
| Briskodian Join Date: Apr 2006 Location: Sheffield
| Re: Noise after starting car Mine is loud enough to hear on start up sometimes. It varies between temperature i think as it sounds louder when its really cold |
| Re: Noise after starting car Thanks guys Its noisy enough to turn heads when starting from cold! Looks like its off to the dealer then.... I'll find out how good the Skoda warranty is, never had to use it yet! Graeme |
| Briskodian Join Date: May 2007 Location: Glasgow
| Re: Noise after starting car I know this is a very old thread, but dont suppose there was any answer to this? |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
| Re: Noise after starting car It was probably his Secondry Air pump as described, but this guy ain't been back since May. Try PMing him maybe |
| Briskodian Join Date: Dec 2006
| Re: Noise after starting car Mines ok but my friends 04 vrs had a bad noise on start up and it got louder turned out the secondary air pump was the prob the rivetts had rotted and the fan had started to come apart hence the blowing kind of noise |
| | #10 |
| Briskodian Join Date: Oct 2006 Location: leeds
| Re: Noise after starting car its air leaking from the secondary air pump making it louder, saw a thread on here before...do some searching, its a quick and cheap fix.
__________________ Mods, Colour coded grille, DVD player, Fancy headlights, Whooshy thing, One of them brillo pad filters where the car sucks air in, and windows upgrade on the cpu from ME to Vista! |
| | #11 |
| Briskodian Join Date: Jul 2007 Location: Kent
| Re: Noise after starting car Quote: a horrible noise after starting, like the exhaust is blowing badly. Surely the air pump would be more of a whiny noise??? Can you attach a sound clip to this thread? |
| | #12 |
| Re: Noise after starting car the noise is similar to a diesel at start up is how i would describe it. Trusty YouTube to the rescue ![]() YouTube - seat leon cupra engine noise!!! is what mine sounds like |
| | #13 |
| Re: Noise after starting car Sounds about right to me, maybe a little more noisey than mine but that may be the recording |
| | #14 |
| Briskodian Join Date: Dec 2007 Location: East Lothian
| Re: Noise after starting car Although my car also has a noise on start up on cold, it sounds nothing like that (but it's great to actually hear the noise that is being discussed!). It sounds more like starter "over run" and only lasts for a second or two at most. It only happens with the first start of the day too. Does/has anybody have/had this? |
| | #15 |
| Re: Noise after starting car ah yes but no.... you can clearly hear there is 'ssssss' noise, which indicates an air leak.... That to me is not the noise of a blowing exhaust. |
| | #16 |
| Re: Noise after starting car My 2004 RS also sounds "raw" after a cold start-up. The rawness vanishes completely after warming up for a few moments. Seems harmless. |
| | #17 | |
