Noisy Secondary Air Pump
This is a discussion on Noisy Secondary Air Pump within the Octavia I forums, part of the Skoda Model Discussion Area category; Hello, I know that when my '01 vRS starts up from cold the seconday air pump starts and then stops ...
Old 16-10-2007, 13:40   #1
Ads
Hello,
I know that when my '01 vRS starts up from cold the seconday air pump starts and then stops when the car has warmed up. However, for a week or so the pump has been very noisy - sounds like exhaust is blowing, except the engine sounds normal after the pump has gone off.
Is it possible a hose is loose? I've tried checking hoses but, to be honest, I don't know which hoses are relevant as I don't know where the air pump is! Can anyone describe exaclty where it is?
Also, does anyone know the cost of replacing the air pump if it is knackered?
cheers.
Ads is offline
Old 16-10-2007, 15:28   #2
Light Jockey!
LJ_Matt's Avatar
Re: Noisy Secondary Air Pump
Can't help you with location but mine was replaced under warranty (thank god!) - pointed out by the dealer while in for other work .
I was told the cost was about £400 , although if it's just noisy I'd probably live with it for that money.
Regards,
Matt
________________________________________________
Assumption is the mother of all foul ups Now proud owner of a Kawasaki ER-6F too!
LJ_Matt is offline
Old 16-10-2007, 17:29   #3
kenny rsell's Avatar
found this link on here not long ago, good step by step instructions for fixing sec/air pump. hope its of use
Step-by-step guide for repairing the Secondary Air Pump (with pictures) - uk-mkivs
Diamond silver octavia vRS,xenons,Jetex downpipe with sports cat,Jetex cat back system,Green panel filter,Forge i pro remap,Forge 007 dv,Milotec bumper grills,TT arch vent mod.
kenny rsell is offline
The Following 2 Users Say Thank You to kenny rsell For This Useful Post:
DGW (17-10-2007), VRSPhil (18-10-2007)
Old 17-10-2007, 07:11   #4
Ads
Thanks. That guide does sound like the noise I'm getting. However, I don;t have the following...
Tools used:
Trolley Jack
Axle Stands x 2
T20 Torx screwdriver
or MECHANICAL ABILITY
Ads is offline
Old 17-10-2007, 13:38   #5
lordrobs's Avatar
Mine sounds awful too Are they actually needed? My car runs like crap when the air pump is going then as soon as that stops its smooth as silk
lordrobs is offline
Old 18-10-2007, 09:03   #6
mine might be suffering from this, only when its started from dead cold. It doesnt sound mechanically wrong just burbles like a scooby for 30 seconds or so before it gets a bit warm.
Mods, Colour coded grille, DVD player, Fancy headlights, Whooshy thing, One of them brillo pad filters where the car sucks air in, and windows upgrade on the cpu from ME to Vista!
duke of hazzard is offline
Old 18-10-2007, 09:08   #7
SMOGUS MAXIMUS
Beretta's Avatar
What does the secondary air pump actually do ????????
Skoda performance was "IMPOSSIBLE", now its Japanese and 177 bhp and 295 lb ft torque of SMOG.
Gerry
"HONI SOIT QUI MAL Y PENSE"
Beretta is offline
Old 18-10-2007, 09:11   #8
according to the guide its used to get the cat upto temp and feeds air to the crank case breather. id describe the noise very differently to what the golf lot say it sounds like, most of my noise seems to just be the Carbonio sucking extra hard (ooh err!) while it warms up over the first 30 seconds or so.
Old 18-10-2007, 13:16   #9
Ads
Well the noise seems to have stopped now.
However, this seems to be because the air pump is now not starting at all!
So it looks like it might be deceased, as it was a cold start this morning.
Backing up a further question - is it actually necessary or does it just reduce emissions?
Ads is offline
Old 18-10-2007, 13:38   #10
woodenspatulas's Avatar
as above, its to help the cat get up to temp quicker. helping it last longer. so its not really needed. i cant speak for skodas but the later versions of my engine in my vectra hadnt got secondary air pumps anyway! so it cant be all that necsary
Where has my sig pic gone????
woodenspatulas is offline
Old 18-10-2007, 13:46   #11
It helps reduce cold start emissions by pumping filtered air into the exhaust manifold. The air mixes with the exhaust gases and helps burn pollutants and generate extra heat to bring the cat up to operating temp more quickly.
Hope this helps.
bill.
vrs180 is offline
The Following User Says Thank You to vrs180 For This Useful Post:
Beretta (18-10-2007)
Old 18-10-2007, 13:51   #12
SMOGUS MAXIMUS
Beretta's Avatar
Was just wondering, as others are, what happens if you run without it???
Gerry
Beretta is offline
Old 18-10-2007, 14:22   #13
I dont know.... I suppose it might put on a CEL light ?
If your feeling brave, you could try pulling out the relay and see what happens.
Go on...I dare you
bill
vrs180 is offline
Old 18-10-2007, 18:06   #14
SMOGUS MAXIMUS
Beretta's Avatar
Go on...I dare you
bill
In the forces I learned never to volunteer for anything................
Gerry
Beretta is offline
Old 18-10-2007, 19:00   #15
Need more power
martziniuk's Avatar
The pump warms the cat up quicker on cold start. Without the pump the emmisions would be worse, but would the engine be pumping slightly unburnt fuel through and is there a possibility this could damage the cat?
I personally wouldn't have thought so but who knows.
Regards Martin
Turbo back blueflame exhaust ,Forge 007p Dump valve,Prosport boost gauge, Autobahn88 TIP, Ecu Evolution Remap, FMIC
martziniuk is online now
Old 18-10-2007, 22:40   #16
mattbeef's Avatar
I didnt think that the car would drive unless you left it to idle for a few moments before?
Im sure that i read the above to vag20v as someone with a golf had the secondary air pump go
I few bits here and there but im happy to Performance Torque
Go on click me you know you want to
mattbeef is offline
Old 18-10-2007, 23:16   #17
Liverpool-Lad's Avatar
I drive away straight after startup. No problems.
2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!
Smiles all 'round
Liverpool-Lad is offline
Old 19-10-2007, 07:16   #18
Need more power
martziniuk's Avatar
Me too and mines got 100k on the clock.
So does this fix just reseal the pump? as thats the way it looks.
Regards Martin
Old 19-10-2007, 09:27   #19
I had the same problem from cold start with mine.I put it in to the local skoda dealership who done a diagnostic check which came up secondary air pump was faulty.They said it was £271 for a new one and £100 to fit.All it does is warm up the cat quicker so that we dont pollute the atmosphere as much.When i asked if the acr would drive ok they said it would be fine and wouldn't affect performance or emissions for mot.Eventually when it does pack up completely they said the engine management light might come on which they can cure as and when for £30.Its alot of money for naff all really unless your an eco warrior of course.Hope this helps.
batfink is offline
Similar Threads
Secondary Air Flow Conundrum! arkangel Octavia I 11 29-11-2007 20:29
Secondary air pump bassman Maintenance & Performance 5 03-03-2007 10:47
Secondary air pump jonboy Octavia I 6 15-11-2006 11:07
Second time secondary air pump failure???? roblatus Octavia I 0 11-01-2006 20:06
Secondary Air Pump Testing yellowmehari Maintenance & Performance 3 20-03-2005 21:09
