This is a discussion on Octavia 1.8L engine running problems within the Octavia I forums, part of the Skoda Model Discussion Area category; I have a 1999 model octavia 1.8/20V 92kw engine. The engine vibrates as if one cylinder is not working. The ...
| Briskodian Join Date: Jan 2008
| Octavia 1.8L engine running problems I have a 1999 model octavia 1.8/20V 92kw engine. The engine vibrates as if one cylinder is not working. The problem happens only in the warm up phase after driving for about an hour. I smell petrol during cold start with some signs of backfiring/explosions in the exhaust pipe only in this cold start phase. No fault is registered in the ecu memory. I have done series of test including air leaks-non found. Temp sender replaced, fuel pressure checks done,airmass sensor replaced with new.Learnt values erased with VAS5051, throttle re-adapted. Still no go.Injectors seals checked-ok.Powers supply to ecu checked-12V ok. black Sooth found on spark plug tips and periodic poor acelerator response. I have high fuel consumption as well. Spark plugs changed but still no success. ![]() I would be happy if any of you experience guys could give me some tips on this issue/or if any one has experienced such problems before. Thanks. TFSI |
| General running problems....next steps.. | Johnny50 | Octavia I | 36 | 18-08-2007 12:41 |
| ...continued running problems... | badgerbrain | Octavia I | 0 | 30-07-2005 10:45 |
| Help With Running Problems!!! | clarkie | Octavia I | 16 | 12-07-2005 21:17 |
| Octavia running problems... | badgerbrain | Octavia I | 7 | 25-06-2005 14:10 |
| Running problems on RS | sgreen | Maintenance & Performance | 19 | 08-03-2005 00:29 |
