This is a discussion on octavia 1.9 td within the Octavia I forums, part of the Skoda Model Discussion Area category; hard to start when engine is warm can anyone help...
| Briskodian Join Date: Jan 2007
| octavia 1.9 td hard to start when engine is warm can anyone help |
| Briskodian Join Date: Jun 2005 Location: Midlands UK
| Re: octavia 1.9 td I get this too (I've got 90bhp 1.9Tdi). I usually just keep cranking and hold the throttle down slightly - gets in going in the end. Would be interested to know why though! |
| Re: octavia 1.9 td Temperature sensor in the injector pump (can be repaired by a derv injection specialist and you don't need a whole new fuel pump). Also check the vacuum pipes. I take it you have checked that the glow plugs are working ok, not that it should affect a hot engine. IIRC sometimes the coolant temperature sensor can have a bit of a funny too. Sure somebody who knows more on this one will be along soon.
| Re: octavia 1.9 td Guys, please answer separately. Does the engine spin as quickly on the starter motor when it's hot as when it's cold? |
| Re: octavia 1.9 td My car suffers this after a longish drive (as I do daily for work). If i stop for fuel when I have reached my home town. When I turn the key, it spins at the normal speed (as when cold), but refuses to catch for about 5 seconds, and then starts. Mine has a new coolant sensor a few months back, and then a while later I noticed the problem starting, but that did then coincides with me changing jobs and then having a long commute to/from work. Last edited by mbames; 22-02-2007 at 17:18. Reason: spelling |
| Briskodian Join Date: Dec 2006
| Re: octavia 1.9 td Try searching for egr (exhaust gas recovery) valve on this forum. I changed my starter motor after similar symptoms only to find egr clogged with gunk. |
