This is a discussion on Octavia 1.9 tdi 110 flat spots? within the Octavia I forums, part of the Skoda Model Discussion Area category; I have a 2002 1.9 tdi Ocy 110bhp which has developed a rather large flat spot under load, especially noticable ...
| Briskodian Join Date: Apr 2008 Location: Stourbridge, West Mids
| Octavia 1.9 tdi 110 flat spots? I have a 2002 1.9 tdi Ocy 110bhp which has developed a rather large flat spot under load, especially noticable in 3rd gear & 4th gear, when its warm. The cars only done 50k, with service history (not that that means anything) and ive already changed the air filter (black and full of crap), fuel filter, oil & filter, but the flat spot is still there, mostly from 2800 rpm onwards. The car had a new turbo at 20k under skoda warranty because of the "overboosting /stuck VNT" problems, and it boosts nicley up to the flat spot. The car doesnt lose total power just feels very restricted. I'm leaning towards a poorly MAF sensor? Would a plug in on vagCOM diagnose this? Any advice greatfully received! Matt |
| Re: Octavia 1.9 tdi 110 flat spots? just been thinking, that when i get this flat spot, theres a real smell of "heat / burning" coming into the cabin as well. Plus the turbo sounds very noticable at low revs, and on boost. Could it be something as daft as a leaking boost hose? and the heat smell is leaking exhaust gasses? Ive arranged a VAG - com plug in saturday morning to try and rule out the obvious ones! Matt |
| Briskodian Join Date: Sep 2006 Location: Walsall
| Re: Octavia 1.9 tdi 110 flat spots? MAF Sensor, probably. Unplug it. The car should feel *much* worse. If not, the sensors screwed. You can confirm by VAG-COM logging MAF actual and expected values while booting it around the block flat out. It won't neccesarily store any codes for a failed MAF. [edit] Just read your 2nd post. Do you have a pipe that has dropped off?
__________________ -- Chris ---------------------------------------------------- The Devil may care, but I don't mind. |
| Re: Octavia 1.9 tdi 110 flat spots? I'd do the MAF test first, cos it's easier rather than cos I think it's the problem. |
| Re: Octavia 1.9 tdi 110 flat spots? No theres no obvious pipe thats fell off, i meant maybe the start of a split or a loose clip somewhere? Its just the smell of "heat" that made me think of that. The air filter that i took out saturday morning was very very very dirty. Could that have in effect caused a problem with the MAF sensor? I know its all irelevant until ive been "plugged in" just picking your knowlegable brains! |
| Re: Octavia 1.9 tdi 110 flat spots? It could be a split, or some of the joints down around the intercooler are pretty hard to see without taking off chunks of plastic. Hence why I said the MAF test was easier to do! There's no "air cleaner bypass pipe", so a mucky cleaner wouldn't hurt the MAF unless someone mucked up cleaning the bottom of the airbox. |
| Re: Octavia 1.9 tdi 110 flat spots? Cheers for the responses guys! I appreciate its a common problem (ive spent hours using the search function today - even though i'm "supposed to be at work LOL"), and i'm grateful for any advice you can give! Matt |
| Not anymore Join Date: Oct 2007 Location: Bournemouth
| Re: Octavia 1.9 tdi 110 flat spots? Agree also maybe the MAF and could be a hose split or adrift somewhere.
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon ![]() Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red Paul ![]() I only live for GTA IV |
| Re: Octavia 1.9 tdi 110 flat spots? Quick update - I had the Ocy plugged in yesterday and the first trouble code stored was Coolant Temp Sensor, then they did a number of "on the road" tests with the VAG hand held computer and came up with the MAF sensor being out of range at higher revs. So it looks like its the cheaper, easier option all round! The turbo was functioning spot on, so thats another weight of my mind. Thanks for all the advice folks! Matt |
| | #10 |
| Re: Octavia 1.9 tdi 110 flat spots? Glad you sorted it out and a cheaper result !!
| | #11 |
| Re: Octavia 1.9 tdi 110 flat spots? Update - Fitted the new genuine MAF sensor and all is well in the skoda camp! It now pulls much much better through the entire rev range, the funny smell has gone and its all together much more like the 50k car it is! Mind you, saying that the interior lights now playing up from the drivers door - possible the door ajar switch in the drivers door lock assembly? never a dull moment in the skoda owning world eh? |
| flat spots with performance filter | smstext | Octavia II | 12 | 05-02-2008 18:56 |
| Loss of Power / Flat Spots 110 TDi | securespark | Octavia I | 31 | 15-12-2007 21:19 |
| flat spots | harryhill | Favorit, Felicia, Fun and Forman | 3 | 01-08-2007 09:21 |
| flat spots and black smoke | george_lungu | Octavia I | 0 | 03-02-2007 22:51 |
| flat spot c. 2.2k rpm, tdi 110 | slidejules | Octavia I | 4 | 15-05-2006 18:22 |
