Octavia Air Con Not working
This is a discussion on Octavia Air Con Not working within the Octavia I forums, part of the Skoda Model Discussion Area category; Have an issue with my aircon on a 2000 TDi 110. Something has dropped off and the aircon doesn't engage ...
Old 09-05-2006, 16:01   #1
Salad Dodger's Avatar
Default Octavia Air Con Not working
Have an issue with my aircon on a 2000 TDi 110. Something has dropped off and the aircon doesn't engage anymore. It is the Climatronic version and the fan and all the other gubbins work ok but the aircon won't engage. When digging aroud under the car a nut dropped out from nowhere which I assume has something to do with it!!!
I am wondering if anything vital has left the car and is now keeping the wildlife company on the side of the M4 somewhere.
Are there any diagrams showing the aircon system under the bonnet? Or has anyone else experienced the same issue?
Sorry for the lack of information but that is a technical as I get when looking under the hood!!
Cheers
Salad Dodger is offline
Old 09-05-2006, 16:09   #2
L&K TDI's Avatar
Default Re: Octavia Air Con Not working
Sounds like the clutch on the compressor has bit the dust. Very common problem
It happened to me last summer and meant having a new compressor fitted, luckily it was done under warranty. If you’re out of warranty I think you could be looking at about £1000 to sort it.
Sorry to be the bearer of bad news.
L&K TDI is offline
Old 09-05-2006, 16:18   #3
I will have to read the non Skoda warranty that I took out with the Skoda Dealer - hopefully it should cover it or it is going to be a very hot summer!!
On the plus side - hoooray for Aircon and a Sunroof on the Elegance!!
Cheers for the reply
What Revelations should say - 'Here is wisdom. Let him who has understanding calculate the colour of the beast, for it is the colour of the Skoda: The colour is Dynamic Blue'
Old 09-05-2006, 18:26   #4
Hairy Yeti
Lummox's Avatar
Repair costs will be around a grand for that, bummer when it happens but as said pretty common.
Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is online now
Old 09-05-2006, 23:54   #5
cheezemonkhai's Avatar
As per previous thread, can you not just get a new clutch for a compressor and haev the bolts rethreaded or is there some reason you can't do that?
cheezemonkhai is offline
Old 09-05-2006, 23:59   #6
Hairy Yeti
Lummox's Avatar
It is one nut that holds the clutch on. usually the end is corroded up and not re useable. Also the heat build up before it fails knackers the end bearing up in the compressor.
Also the clutch has to be shimmed up exactly right or the same thing will happen.
Old 10-05-2006, 00:01   #7
ahh well,
Do you need to get the plastic off to see this thing as i may get some loctite on mine just to make sure. Either that or ask dealer to do it while it's in for some work.
Old 10-05-2006, 00:05   #8
Hairy Yeti
Lummox's Avatar
If you want them to do anything worth while gett hem to check the condition of the clutch and the clearance on the coupling to check its running clearance is ok.
Old 10-05-2006, 00:11   #9
Thanks
Would damage there be covered under warrenty or is it a pay yourself as it's a clutch? Also how much are the parts/labour.
Old 10-05-2006, 07:18   #10
Hairy Yeti
Lummox's Avatar
Warranty would cover any damage but if its working there isnt a fault.
Old 10-05-2006, 09:24   #11
It seems there are a few 2000-2001 Octavias which are having problems with compressors failing, because the clutch bit falls off. You can add mine to the few
I bought my 2001 1.9Tdi Elegance(110bhp) saloon with 60000 miles on the clock under the Skoda approved used car scheme from Dennis Horton and Son in Lincoln, last September.
During the winter the climatronic system was set to Auto. I can't remember if there were any hot days between the time I bought the car and last week when the first hot day resulted in no cooling from the system.
I was told that although 8 months into the 1 year warranty, my problem is not covered in the warranty and have been quoted £837 to fix it.
I feel very unhappy that this has happened because there is no way I am paying that amount to fix the problem which in my opinion may have occurred due to a design fault in cars built around that time?
I am cynical and think it may be the case that Skoda know there are problems with compressors failing like this and that is why it isn't covered in the used car warranty scheme.
I am upset because unless goodwill is shown to me and the problem sorted out by Skoda UK and my dealer, then I am left with a car that in the future I will not be able to trade in for another one because of this known expensive fault.
I would not be happy to try to sell the car privately knowing such a big fault would be passed on to the next owner. So I will be stuck with an octavia with no cooling function from the climatronic system for as long as I continue to own the car.
I am waiting for Dennis Horton to get back to me to see how we are going to resolve this problem.
tikhon is offline
Old 10-05-2006, 09:40   #12
Decapodian
Dr Zoidberg's Avatar
This does seem to be happening quite a bit on cars that are on around 80k miles or more.
Of course a lot of people are only noticing the problem now that the weather is picking up and the aircon is needed
Alex
www.drzoidberg.co.uk
Dr Zoidberg is offline
Old 16-05-2006, 10:34   #13
Went to see the service manager at Dennis Horton and Son in Lincoln. They were prepared to contribute 30 per cent of the cost as a goodwill gesture. So 30 per cent of £837 leaves me with an option to have cool air that will cost me over £500 to fix.
The service manager acknowledged that the clutch coming apart from the compressor is a fault that occurs and that when they service cars they 'check the nut is tight'.
He also acknowledged that the Skoda used car warranty really should have covered this expensive failure.
I will simply drive the car and in hot weather, use the sunroof and windows as my air conditioning! Shouldn't have to, but there are far more important things in life to be concerned about!
My advice is check your nuts are tight and search for a used car warranty that covers this potentially expensive failure.
tikhon is offline
Old 16-05-2006, 11:03   #14
£500 seems not that bad really when you consider you can sell it on for more.
Also have you tried an air con specialist. They may be able to source an OE compressor for less.
Old 16-05-2006, 22:47   #15
Agree try aircon specialist I had the compressor replaced on my car (not a Skoda) including fan belt for around £500, main dealer charge just for fitting the compressor was £1,000 this was over 2 years ago and no problems do date and the best thing the replacement was done at my home
SKOD is offline
Old 19-05-2006, 08:50   #16
SimonS's Avatar
Have a read of this post http://www.briskoda.net/forums/octav...ty-help/52147/
I got my aircon fixed for £145. You can buy a genuine complete compressor (brand new) from ebay/internet for around £300. I was fortunate in that my compressor seemed ok, and I managed to get a brand new clutch for only £51 on ebay. The spindle was damaged on the end of the compressor, but they managed to rethread it ok.
SimonS is offline
Old 21-05-2006, 17:38   #17
DGW
BRISKODA Staff
DGW's Avatar
There is currently an airconditioning compressor and receiver dryer for sale on eBay here, but do check that it is the right part number before buying:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
Denis
2007 Fabia vRS - CC, ESP, Jabba rear ARB, and full leather trim by Seat Surgeons ...48.01 mpg...
DGW is offline
