This is a discussion on octavia brake pads within the Octavia I forums, part of the Skoda Model Discussion Area category; Am looking to renew my pads,wear indicator light just come on.Does anyone know with what degree of urgency I must ...
| Briskodian Join Date: Sep 2006
| octavia brake pads Am looking to renew my pads,wear indicator light just come on.Does anyone know with what degree of urgency I must replace them.Also anyone done this job?No manual from Haynes et al leaves you in the dark.Any tips on what to unbolt or anything else I would be grateful for |
| Re: octavia brake pads Pads, do them ASAP to save possible damage to your Discs. At the same time you would want to check your disks as you may need to replace these too. Which Octavia do you have. I asked the question a while ago for FSIII brakes, and these are really easy to change the pads on. HTH
| Re: octavia brake pads Haynes have recently produced a manual for the Skoda Octavia - 1998 to April 2004 - ISBN 1 84425 285 X.
| Re: octavia brake pads Thanks both for the really useful info |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
| Re: octavia brake pads They are dead easy to change - take about 30 minutes. Where are you based?
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| Briskodian Join Date: Jan 2005 Location: Manchester UK
| Re: octavia brake pads If you do the rear pads make sure you wind back the pistons or you will strip the thread for the handbrake.![]() |
| Briskodian Join Date: Jan 2004 Location: Up a tree.
| Re: octavia brake pads There is a Haynes manual for the Octavia. The VW Golf manual that covers the same year as your car will also cover this. The wear indicator is on the nearside front hub, inner pad. One our Octavia the offside inner pad was down to the metal by the time the wear indicator came on. So, based on my experience I'd advise you to change them ASAP. |
| Re: octavia brake pads Ohhh.... I had a quick glance at mine (2001 Elegance) and assumed it did not have a wear indicator.... I'll have a closer look next time I am under the car (ie. next weekend to check the state of my air con :-( ) |
| Re: octavia brake pads Yeah it does have one Mat, as said there is a wire on the front passenger side pad.
