Octavia Fans Stuck On, HELP!!!!
This is a discussion on Octavia Fans Stuck On, HELP!!!! within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi there, I am having a nightmare with my dads octavia. Its a 1.6 avu engine, 2000 model. Basically the ...
Old 28-09-2006, 12:05   #1
Hi there, I am having a nightmare with my dads octavia. Its a 1.6 avu engine, 2000 model. Basically the fans come on as soon as you turn the ignition on and you have to disconnect the battery in order to stop them. Now this started when he overheated last week, which was put down to the elecrothermostat, changed that, seems to open and close fine, but I was told this would also cure the fans, but alas no. Now im also told there is a fan run on relay, which may well be knackered, but Im buggered if I can find it, on a golf its number 181 in location 13, but im well and truly stuck, any advice would be great. Cheers.
bennymole is offline
Old 28-09-2006, 12:26   #2
Briskodiodion
TeflonTom's Avatar
Re: Octavia Fans Stuck On, HELP!!!!
i expect the fan switch has shorted out.
TeflonTom is offline
Old 28-09-2006, 12:29   #3
The one on the rad? I thought that would not work if the ignition was off?
Old 28-09-2006, 12:32   #4
Briskodiodion
TeflonTom's Avatar
i cant think of a good way of explaining this.........
they dont normally...... but it does work for a set period of about 10mins after the engine has been switched off.
Old 28-09-2006, 12:34   #5
Briskodiodion
TeflonTom's Avatar
try unplugging the the fan switch then turning on the ignition to see if the fan still come on or not
Old 28-09-2006, 12:35   #6
Right o, im off to do that now. Cheers.
Old 28-09-2006, 12:37   #7
One more thing, any ideas where the relays are? Ive got a couple under a black cover in the engine compartment, 4 or 5 under the steerring column, any more anywhere else?
Old 28-09-2006, 12:47   #8
Tried unplugging the fan switch and it doesnt change anything, fans come on and carry on regarddless!!!
Old 28-09-2006, 18:55   #9
Cupra Bush King
Lummox's Avatar
Images: 2
It can be,
Faulty fans (my educated guess)
Fan relay unit (under n/s chassis leg under battery (gets water in it)
An air con fault (maybe excess pressure)
Any fault codes you know of?
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is online now
