This is a discussion on octavia fuses / fusebox within the Octavia I forums, part of the Skoda Model Discussion Area category; hi, ive been sent here from somewhere else. anyway, basically ive got one with an electrical leak. some bright spark ...
| Briskodian Join Date: Jan 2008
| hi, ive been sent here from somewhere else. anyway, basically ive got one with an electrical leak. some bright spark (maybe me, maybe not) pulled out all the fuses. anyway the diagrame in the book is lhd and nothing like the actual box. we can i get the right diagram? the skoda diagram ![]() the actual box ![]() my diagram ![]() engine cover ![]() top left to right: in the skoda diagrame numbers go Code: 8
5 9
1 3 6 10
2 4 7 11 etc
Code: 20 16 12 21 17 13 22 18 14 23 19 15 etc ive been sent the link http://www.briskoda.net/forums/octav...-layout/88051/ but none of the numbers on the car fusebox match up with the numbers in the book. i realise there 'mirrored from lhd to rhd, but none of the number functions add up (ie the wipers are 24 and not 21, or that full beam is 18 and 19, not 15 and 16). help!!!!! if anyone cares ive been sent from octavia fuses - Talk Audio Forums cheers. |
| Re: octavia fuses / fusebox anyone? ive been sent ![]() but the problem with the above is, that if you look at the top left on your photo where the 2x 15amp fuses are, they do the dip/low beam. if you look in the book (#17 and 18) they should be 10amps. ![]() |
| ECUless Join Date: Mar 2005
| Re: octavia fuses / fusebox What are you trying to do?, put the fuses back in your fusebox, except that you don't know which power fuse to put where? Headlamp dipped beam is typically 55 Watt which will need a current of around 5 Amps continuously, if both were on the same circuit then the fuse would have to take 10 amps continuously, so for a single dipped beam use a 10 A fuse and for two running through the same fuse use a 15 Amp. The same applies to the main beam circuit. If you divide the watts by the voltage (typically 12 in a car) you will get the current Amps that is required. |
| Briskodian Join Date: Dec 2004 Location: Hawkinge Kent
| Re: octavia fuses / fusebox The diagram is a mirror image, just reverse it. Do xenon headlights have 15A fuses instead of 10A? Or maybe whoever sent you the photo had uprated the headlight bulbs, blew the fuses so uprated them - a common thing a lot of people do. ![]() In any case just reverse the diagram and fit them back in that order, it is confusing though, how hard would it be for VAG to produce a LHD & RHD book?? ![]() |
| Re: octavia fuses / fusebox Why, unless there's a striking load (like older household flourescents), would Xenons need higher wattage fuses, since they only draw about half the current? Last edited by KenONeill; 18-01-2008 at 14:58. |
| Re: octavia fuses / fusebox Thats why I'm asking, i know xenon only have a 35W 'bulb' compared to a 55W halogen, but they first have to power the ballast then they have to arc the lamp itself. I seem to remember (on here i think?) somebody kept popping the 10A fuse after they had retro fitted xenons. (mine run fine on the std 10A fuse though) |
| Re: octavia fuses / fusebox Is this what you are looking for? ![]()
| Re: octavia fuses / fusebox does anyone know which is the fuse for the airbag light on the dashboard?i don't know for the skoda but i'm sure that for the VW is the number 15 5Amp light brown,is it the same for a skoda octavia TDI '00?many thanks |
| Re: octavia fuses / fusebox The airbag light is a LED, it draws a very low current and would not need a fuse. What's the problem with it? |
| | #10 |
| Re: octavia fuses / fusebox well the led is on,something wrong with the airbag i didn't mean the fuse for the led but for the airbag sistem.should be somewhere?i'm been to the garage be4 and it's been reset but after 50 miles it was on again sorry but i don't throw £25 everytime i pop in the garage and waste my time........i know also that i don't have an error code if i use the vga.com...what should i do cut off the led and good bye? |
| | #11 |
| Re: octavia fuses / fusebox I'm wondering about a loose connection, in which case good luck! |
| | #12 |
| Briskodian Join Date: Sep 2008
| Re: octavia fuses / fusebox Hi there - on the subject of fuses, I'm wondering whether the cd changer in the boot is fused, if so which one - its mysteriously stopped working and doesn't appear damaged - fuse???? Thank you, burto |
| | #13 |
| Re: octavia fuses / fusebox Got a message on the head unit Burto? If so, and it's either "Surface" or "Mechanic", remove the magazine, count to ten, refit it, and leave the car for a bit usually works. |
| | #14 |
| Briskodian Join Date: Nov 2008
| Re: octavia fuses / fusebox Hi I managed to get a clear fuse box diagram with the numbers for all to see. Hope this helps. |
| The Following User Says Thank You to Jago For This Useful Post: | KenONeill (10-11-2008) |
| | #15 |
| Not anymore Join Date: Oct 2007 Location: Bournemouth
| Re: octavia fuses / fusebox Ah thats useful thanks
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon ![]() Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red Paul ![]() I only live for GTA IV |
| Fusebox | natesvRS | Octavia I | 0 | 17-11-2007 11:52 |
| Replacing Fuses - 2001 Octavia | iain1976 | Octavia I | 3 | 20-09-2007 08:41 |
| Fuses for car radio / octavia | MatevzH | Octavia I | 0 | 09-09-2007 12:47 |
| fuses/ fusebox | wonfa | Octavia I | 12 | 11-02-2007 19:19 |
| Fabia fusebox | robert79 | Maintenance & Performance | 9 | 13-07-2004 22:47 |
