This is a discussion on Octavia I 4x4 - Spec within the Octavia I forums, part of the Skoda Model Discussion Area category; Basically I am looking into buying a Mk1 Octavia 4WD version and I am wanting to get the full spec ...
| | #1 | |
| Briskodian Join Date: Apr 2008
| Octavia I 4x4 - Spec Basically I am looking into buying a Mk1 Octavia 4WD version and I am wanting to get the full spec of the car down with as much info on it as I can. I am really wanting to build up some pictures aswell so if you have any pics of the 4WD underside, engine bay, interior, exterior could you send me them at: andrew.a.gray at gmail.com I am also searching for good pics to show the colour of a Black "Black Magic" Octavia. Please correct me if anything I post is incorrect - thanks! Here is what I have sourced so far: Quote:
| The Following User Says Thank You to AndrewG For This Useful Post: | 4x4mark (30-04-2008) |
| Briskodian Join Date: Apr 2006 Location: Sheffield
| Re: Octavia I 4x4 - Spec seams reasonable info apart from the clutch info. provided you drive normally and dont make a habit of full throttle launches it will be fine |
| The Following User Says Thank You to mattbeef For This Useful Post: | AndrewG (29-04-2008) |
| Re: Octavia I 4x4 - Spec Thanks Matt. Does the 4x4 doesnt come with colour coded bump strips does it ? |
| | #4 | |
| Re: Octavia I 4x4 - Spec Quote:
http://briskoda.net/forums/skoda-car...e-sold/106601/
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... Last edited by DGW; 29-04-2008 at 22:51. | |
| The Following User Says Thank You to DGW For This Useful Post: | AndrewG (29-04-2008) |
| Re: Octavia I 4x4 - Spec Excellent, thanks Denis. *edit* I found Eddy's car earlier on, one of the first threads I looked at in the for sale section - absolutely stunning car! Hopefully a nice Black unmodded 4x4 comes up for sale soon that I can snap up! ![]() |
| Re: Octavia I 4x4 - Spec My 4X4 is set for variable service intervals and gets serviced every 2 years. The variable service intervals can be anywhere between 15000 and 30000 km depending on driving style, with a 24 months maximum time limit. The cambelt change interval for the 1.8T is a maximum of 120,000 miles or 4 years, whichever comes first. It is wise to change the water pump at the same time as the cambelt since the plastic impellers can and do suffer premature failure. The air filter change interval is the same as the sparks plugs - 40000 miles. The Haldex needs an oil change every 20000 miles and a filter change as well every 40000 miles. Climate control is standard; rain sensor wipers are not. The CD changer is in the boot. Cruise control is not standard but can be retrofitted. I am not aware that the rear springs wear out any sooner than the front. Insurance group is 14 - the vRS is 16. The engine is as tuneable as that in the vRS, less a couple of bhp. Mine is remapped and has averaged 31.97mpg over 25069 miles. The car was and still is a steal at the price given the extra mechanical complexity over the 2WD versions, ie prop shaft, rear diff, Haldex, IRS etc.
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... Last edited by DGW; 30-04-2008 at 10:23. Reason: Cruise control NOT standard. |
| Re: Octavia I 4x4 - Spec Thanks Denis, a lot of great information I didnt know - appreciated! |
| Briskodian Join Date: Apr 2008 Location: south birmingham
| Re: Octavia I 4x4 - Spec there was a nice black 4x4 one on ebay about a week ago did not sell thought nice cars as ive just brought one and well impressed carnt wait to wake up in the mornings and give her some stick mine never come with cruse control but has everythink else |
| The Following User Says Thank You to 4x4mark For This Useful Post: | AndrewG (30-04-2008) |
| Re: Octavia I 4x4 - Spec I'm having a senior moment in my post above! Cruise wasn't standard but can be retrofitted relatively easily. I had mine done early on in ownership. I have corrected my earlier post.
| | #10 |
| Re: Octavia I 4x4 - Spec So with this 4WD system, the rear wheels only get power when the front loose grip? So say you were powering out of a corner would all 4 wheels have power going through them? Just wondering how good this system is compared to a FWD vRS in the corners. |
| | #11 | |
| Briskodian Join Date: Jan 2003 Location: Winchester
when front slip is detected power is added to the rear but also with the ESP it uses the brakes to stop spinning wheels pushing the power to the ones that have grip. Simplistic explanation but works incredibly well, also very strong. mine is still std with 350 bhp going through it. Just make sure the filters are changed. Re rear springs, they dont wear out as such, they break, Ive also heard of one car breaking the front ones. Def check the aircon, the clutch can come off the compressor, common to all similar VAG cars but a grand at the stealers to sort
__________________ Speed is an addiction for which thankfully there is no cure | |
| | #12 |
| Briskodian Join Date: Apr 2008 Location: Stourbridge, West Mids
| Re: Octavia I 4x4 - Spec Didnt the 4x4 hatch come with a very discrete lip spoiler on the tailgate? I mean, blink and you'd miss it discrete? Matt |
| | #13 |
| Re: Octavia I 4x4 - Spec Yes
| | #14 |
| Re: Octavia I 4x4 - Spec If you search on here it is a bit of a debate whether the clutches are up to much of a remap - mine wasn't, others have been ok. If you don't fit it yourself its not cheap. Other than that its been a good car. Mpg varies from scary 17 to nearly 40. As standard the car rolls too much, but is handy over lumps and bumps, and brilliant in snow |
| | #15 |
| Briskodian Join Date: Jun 2008 Location: Finland
| Re: Octavia I 4x4 - Spec How does Haldex function during engine braking - or does it? My 4x4 oversteers if I step of gas pedal, compared to the Subary Legacy that I previously had. Of course the wheelbase is also shorter in Octavia. |
| Octy 4x4 Spec - what to order? | rkenny | Octavia II | 10 | 22-08-2007 11:33 |
| Spec of battery for 4x4 | EddyH | Octavia I | 21 | 09-11-2006 20:17 |
| New Octy 4x4 Spec question | Stuart_J | Octavia II | 5 | 07-06-2005 16:29 |
| Octavia Spec | ag.morley | Octavia II | 2 | 14-02-2005 09:04 |
