This is a discussion on Octavia More BHP within the Octavia I forums, part of the Skoda Model Discussion Area category; HI I have the 1.9tdi estate on a 03 plate. What is the best way to get the BHP up ...
| Briskodian Join Date: May 2006
| Octavia More BHP HI I have the 1.9tdi estate on a 03 plate. What is the best way to get the BHP up from the current 90. Various people have suggested, remapping the ecu, plugging a preprogrammed unit into the ECU socket etc. Also what BHP would I expect to get and would it effect the mpg. i'm in West Yorkshire, is there anyone local who could do this work and what would be the approx cost. cheers |
| Briskodian Join Date: Apr 2004 Location: rotherham, south yorkshire
| Re: Octavia More BHP Hi I'm not a diesel burner myself but I know they have great potential and really good results can be gained with a re map from a reputable tuner. I am sure someone more knowledgable will be along to help shortly...................
__________________ "Spider pig, spider pig, does whatever a spider pig does"..............(simpsons movie 2007) |
| Cuthbert Dibble Join Date: Apr 2006 Location: Watching Tom peeping at Lady Godiva.
| Re: Octavia More BHP I've looked at loads. I would recommend a remap rather than a chip, and ideally on a rolling road although you'll pay more. Given that you live up north, you might want to consider http://www.revotechnik.com/ because they have branches nationwide. Cost is £399 plus VAT. Cheers, Jon.
__________________ ![]() I drink, therefore I spam. |
| Re: Octavia More BHP I drive a 110, and IIRC the major difference between the 90 & 110 is larger bore injectors (you can fit the 110 injectors into a 90) and the 90's lack of an intercooler I think. So my options would be 110TDi Injectors, an intercooler (Probably get both of these from a breakers) and then a remap. That would probably see you good fora bout 130bhp and a good amount of torque assuming the gearbox and drivetrain can take the torque.
| | #5 | |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Re: Octavia More BHP Quote:
Michael at Jabba has a 110bhp SLX...he mapped it at 200k miles on the clock to 150bhp.....still running fine.....got around 250k on the clock. Stuart_J's SWMBO had ther L&K 110 remapped by Jabba...160bhp IIRC....just sold with over 100k miles.
__________________ Adrian. | |
| | #6 | |
| Briskodian Join Date: Oct 2004 Location: Northern Ireland
I used to have a 90bhp MK3 golf. I bought a digital tuning box and K&N panel filter for it. It went very well, and the mods were value for money (135k miles and no probs). The bonus of the tuning box over the remap was that i just unplugged it when i sold the car, and then sold the box seperately for £100+ The MPG was much the same, maybe better (as most will testify with mods producing 20-30% increase in bhp) and the car put out approx. 115-120bhp. JD
__________________ Octy Elegance TDI (110bhp) | |
| | #7 | |
Any major changes mechanically would require a remap anyway, cause the ECU isn't set up for it as standard, but all that would give substantial power increase at a cost!!
| | #8 | |
| Briskodian Join Date: Jan 2003 Location: Winchester
Re the 90 I would see what can be gained by just a remap initially, as soon as you start miing & matching bits it starts to get expensive & hassle. talk to Jabba etc to see what extra you can expect, you might be pleasantly suprised
__________________ Speed is an addiction for which thankfully there is no cure | |
| Re: Octavia More BHP Can't say i know on the turbo, think you are correct, but not sure. If you do need one you can also get a turbo from a breakers, clean it up and drop it on. Shouldn't be that hard for an experienced tuner to put on I would have thought The others would work without the turbo, but whatever you do make sure you get the remap last as then it can take into account the other mods. Edit: Re the injectors, they literall are a direct replacement, just they put a little more fuel in per squirt.
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. Last edited by cheezemonkhai; 15-05-2006 at 13:52. |
| | #10 | |
![]() Chris
