This is a discussion on Octavia near side headlight glass within the Octavia I forums, part of the Skoda Model Discussion Area category; The glass has been holed by a stone. Is it possible and how do you change just the glass in ...
| Briskodian Join Date: Feb 2008
| Octavia near side headlight glass The glass has been holed by a stone. Is it possible and how do you change just the glass in the headlight unit. |
| Briskodian Join Date: Jun 2004 Location: in the great north west
| Re: Octavia near side headlight glass is it an early octavia or a later mark 1? if it is a later one I am sure I have seen a headlight on ebay today if it helps |
| Re: Octavia near side headlight glass Mine is a 1999 Octavia 1.9Tdi GLX hatchback. The glass can be bought separately from the dealer together with a new gasket. It looks like the glass is held by several spring clips. It may need the whole headlight assembly removing to get all the clips off. Not sure how to do this as the Haynes manual doesn't cover headlight removal. Does the bumper have to be removed to get at the underside ?? Sorted match marked and removed headlight(4 screw bolts) and indicator lens assembly(1 bolt). Unclipped glass cleaned up rebate and fitted new gasket and glass lens (£27 from Skoda dealer). Last edited by joolszowski@hot; 11-02-2008 at 09:10. |
| Briskodian Join Date: Dec 2006 Location: Peterborough
| Re: Octavia near side headlight glass Do you need to remove the bumper to get the headlight unit out? I've got to replace the lens in my headlamp after a stone went through it. |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
| Re: Octavia near side headlight glass Yes and it's it's simple to remove the headlight unit !!! |
| ECUless Join Date: Mar 2005
| Re: Octavia near side headlight glass No need to remove the bumper, we usually remove the right hand one when we do cam belts on the diesels. |
| Not anymore Join Date: Oct 2007 Location: Bournemouth
| Re: Octavia near side headlight glass Just out of interest mate why is that?
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon ![]() Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red Paul ![]() I only live for GTA IV |
| Re: Octavia near side headlight glass It makes it easier to get at the spring clips on the intake ducting from the intercooler, as that nees to come off so that you can get at the engine mount. |
| Re: Octavia near side headlight glass OK thanks
| | #10 |
| Briskodian Join Date: Jan 2008
| Re: Octavia near side headlight glass I´ve changed the glass on the right side and it took me about 10 minutes to do. As said here no need to remove the bumper. |
| Oil behind headlight on off side headlight | Chri5B | Fabia I | 9 | 28-09-2006 12:34 |
| Heated glass for Octavia wing mirror | tonnoir | Octavia I | 10 | 17-11-2005 14:32 |
| Octavia Wing Mirror glass | potholer12 | Octavia I | 3 | 31-01-2005 23:38 |
