This is a discussion on Octavia TDI dont start. within the Octavia I forums, part of the Skoda Model Discussion Area category; My Octavia Diesel TDI will not start. The fuel pump do not get the 12 volt when turning the key. ...
| Briskodian Join Date: Feb 2008
| Octavia TDI dont start. My Octavia Diesel TDI will not start. The fuel pump do not get the 12 voltwhen turning the key. Are there any fuse for this? All indikators in the dashboard are normal. |
| Briskodian Join Date: May 2007
| Re: Octavia TDI dont start. I'm fairly sure there is a fuse for the ECU, which would lead to no turning over if it's blown. Open the driver's door, and the bit of the dash that is exposed by opening the door you can prise this off. There should be a little fuse removal tool. Take the fuses out and have a look. It should be fairly obvious. Although there could be a problem in the starting circuit. How do you measure the voltage to the pump? |
| | #3 | |
| Re: Octavia TDI dont start. Quote:
| | #4 | |
IF i force 12 volt to the pump, its working ok. | |
| Re: Octavia TDI dont start. I measure with a voltmeter. 0.04 volt at keyturn, Should be 12 V IF i force 12 volt to the pump, its working ok. |
| | #6 | |
| Re: Octavia TDI dont start. You seem to know what youre doing. Should you really force 12v into the pump without the help of the ECU? The fuses are easy to look at. It should not take you longer than a minute or two to find a broken one. Just make sure you put them back in the same place! |
| ECUless Join Date: Mar 2005
| Re: Octavia TDI dont start. Relay 109 the X relay for the electrics, or try freeing the anti shudder valve as this can stick blocking air into the engine |
| Re: Octavia TDI dont start. Identify the relevant fuse, and replace it, even if it looks ok. It's rare, but not impossible for a blown fuse to look ok, but not be capable of carrying current. |
| Non start fabia tdi | rigsby | Fabia I | 7 | 13-11-2007 11:48 |
| Octavia TDI wont start Help | hanny1888 | Octavia I | 5 | 07-02-2007 14:54 |
| Refusal to start (TDi) | mbames | Octavia I | 11 | 28-11-2006 11:29 |
| Skoda Octavia Tdi 90 Cold Start | Geoff | Maintenance & Performance | 9 | 01-11-2003 18:47 |
| Dont All Start Crying But ....... | 400 BHP MAN | Off Topic and Chit Chat | 28 | 24-06-2003 08:54 |
