This is a discussion on Octavia temperature sensor failure within the Octavia I forums, part of the Skoda Model Discussion Area category; Hello I'm kind of new to this, so any help will be much appreciated. I have a 2002 Octavia 1.9 ...
| Briskodian Join Date: May 2007
| Octavia temperature sensor failure Hello I'm kind of new to this, so any help will be much appreciated. I have a 2002 Octavia 1.9 TDI 90 which has a problem with the temp dial. VAG COM reads the problem as the coolant temperature sensor, which I understand is a common problem. However, I need a hand in finding it. If you can use easy words please as I'm no mechanic ! The other thing that bothers me is that, if this is overdosing my engine with fuel, could this have led to a 0-60 in 10.5 secs . This is a few secs quicker than the literature says, and road conditions were level, low wind etc. I don't know if the car has been modified in any way. Could the replacement of this sensor slow me down? |
| Re: Octavia temperature sensor failure The picture below shows where the dual temperature sender is on the 1.8T engine - ie to the right of the engine looking from the front of the car. The plastic cylinder head cover has been removed for ease of access. My thumb is resting on the U-clip which secures the sender in place. Your car's should be in a similar location. If the sender is sending the wrong information to the engine ECU, this would affect the correct running of the engine. ![]()
| Re: Octavia temperature sensor failure Thank you sir. And tell me, what is the hose running to the right of the sensor? I find these engines packed full and quite hard to tell what is what. Do you know if a change in the sensor will slow the car down? Martin |
| Re: Octavia temperature sensor failure It might well do. What sort of mpg are you presently seeing? |
| Re: Octavia temperature sensor failure High 50's at the minute. A bit lower this year this year than the last. On some quite small roads too. But neither my wife or I drive the car hard. It had seemed to have a little bit of trouble with the cold starts recently, not too much though. |
| Re: Octavia temperature sensor failure It'll not slow the car down much then I think; I had high 50s or low 60s out of a hired 90, despite spending 2 hours in a 1st/2nd gear crawl caused by a broken down bus on the M25! |
| Re: Octavia temperature sensor failure So you think I'm losing a bit of mpg? |
| Re: Octavia temperature sensor failure Maybe, but not much probably. I don't make a habit of breaking speed limits, but am a quick driver even so. |
| Re: Octavia temperature sensor failure Can I ask you where the relevent part is here? I have a pic above but it is not distinct. I have a feeling it's out of sight on the passenger side of the engine, between the air filter and engine block. |
| | #10 |
| Re: Octavia temperature sensor failure I have found the part but it is a bloody nightmare to service. It is horizontal, which means the coolant runs out like billy-o. Anyone know how to plug effectively for a moment while I replace the sensor? Or should I drain the system? |
| | #11 |
| Not anymore Join Date: Oct 2007 Location: Bournemouth
| Re: Octavia temperature sensor failure Maybe jacking the car up on that side might help so the coolant stays on opposite side?
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon ![]() Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red Paul ![]() I only live for GTA IV |
| | #12 |
| Re: Octavia temperature sensor failure That is a possible. But I'm thinking there must be a way to plug it, even for a minute or two. |
| | #13 |
| Re: Octavia temperature sensor failure Just got to be quick but can always top up after.Won,t be that much loss.
| | #14 |
| Briskodian Join Date: Aug 2006 Location: East Lothian
| Re: Octavia temperature sensor failure I agree, if it is the same as the 1.8 petrol,it just unclips and can be replaced quickly. Remember to fit new o ring and leave filler cap on which will reduce water loss.
__________________ Diamond silver octavia vRS,xenons,Jetex downpipe with sports cat,Jetex cat back system,Green panel filter,Forge i pro remap,Forge 007 dv,Milotec bumper grills,TT arch vent mod. |
| | #15 |
| Re: Octavia temperature sensor failure Thank you all. Completed today with a wee bit of drama! Things to note for anyone unsure is be careful of the clip. Its thin and black and if you have slippy hands, it will end up in the depths of your engine! And the car won't go anywhere! Make sure the sensor is clipped back into place properly as I thought it was but it started leaking coolant several miles from home. Hot coolant, that is, and a bit more difficult to work with than the cold stuff....Also make sure the old sealing ring is removed and the new one placed over the sensor. I found it helpful to clamp all the pipes leading to this area. I was lucky to buy an adjustible clamp set from Lidl yesterday (hurry!). There is a bit of leakage but it comes to a halt or slow trickle soon after. Anyone need a hand with this send me a message. This is for the 2002 non pd 1.9 TDI. I made all the mistakes today, so you don't have to! |
| Outside temperature sensor. | mase | INTRODUCE YOURSELF! First time visitors, say hello here. | 1 | 15-08-2007 12:55 |
| Temperature sensor ? | yaktrebor | Octavia I | 7 | 16-04-2006 17:11 |
| needle lift sensor failure (2000 octavia glx tdi) | peter white | General Car Chat | 0 | 02-09-2004 12:22 |
| Octavia temperature sensor | wonderbadger | Maintenance & Performance | 3 | 01-04-2004 16:01 |
