Octavia: Useful part numbers for Octavia DIY servicing and mods
This is a discussion on Octavia: Useful part numbers for Octavia DIY servicing and mods within the Octavia I forums, part of the Skoda Model Discussion Area category; Skoda OE part numbers Octavia vRS Sill Covers 1U0 853 491A Cover Strip RS-WRC Left Front £22.47. 1U0 853 492A ...
Old 21-03-2006, 14:14   #1
Site owner
ColinD's Avatar
Images: 3
1U0 853 492A Cover Strip RS-WRC Right Front £22.47.
1U0 853 541A Cover Strip RS-WRC Left Rear £22.47.
1U0 853 542A Cover Strip RS-WRC Right Rear £22.47.
Electro change-over valve (N75 wastegate regulator valve) - AGU, AUM, ARX, AUQ engines
058 906 283 F - £56.44,
(Description on box = Dump Valve)
Cut-off valve (DV) - AGU, AUM, ARX engines
06A 145 710 N - £22.69,
(Replaces 06A 145 710 and 06A 145 710 G)
Dual temperature sender (ie temperature sensor) - not AVU/BFQ
059 919 501A 4 pin green 20mm - £25.92
(Replaces 078 919 501C black)
Ignition coil with spark plug connector (coil pack) - AUM, ARX, AUQ, AWT engines
06B 905 115 J
06B 905 115 L
06B 905 115R - £26.50 (from Funky Styling)
The L version was the specified replacement for 06B 905 115 D/G/H which were the subject of a Skoda Bulletin calling for their replacement.
The R version is the latest version.
Air Volume Meter (MAF)
06A 906 461 L - AUM, ARX, AUQ
06A 906 461 A - AQY, APK, AZH, AEG
06A 906 461 G - AZJ
037 906 461 C - AGU
06A 906 461 C - AGR, AHF, ALH, ASV, ATD
074 906 461 B - ASZ .
NB - All these MAFs are now exchange items from dealers. Add X to the end of the part number above for the exchange unit part number. Price on exchange is circa £76.50 excluding a refundable deposit conditional on the old MAF being returned to the dealer.
Pressure hose from turbocharger to charge air cooler
06A 145 790C - £39.96
This modified hose replaces PN 06A 145 790A in the event that the latter shows damage to the socket of the sealing ring. It is also one of the recommended replacements when fault-finding a 17705 fault code.
Throttle valve control unit gasket (1.8T engine)
028 129 748
Warning light (ie modified hazard warning light/indicator relay)
1U0 953 235E 300 - £28.36
vRS (Fabia/Octavia) turn signal, darkened (ie side indicator repeater)
6K0 949 127 - £1.60 each.
Switch - brake light (common to all models)
1C0 945 511 A RDW - £7.76
(latest modified switch - green)
Octavia Estate rear aero wiper complete
6Q6 955 707A - arm
6Q6 955 435A - cap
6Q6 955 425A - blade
Available complete from VAGparts for circa £15.
Octavia Front Brake Lines
1J0 611 701 - brake hose fr. wheel drive
1J0 611 701 G - brake hose 4x4/RS
Octavia Wheels Cap
0U0 601 151L MHB £5.35 (ex vat)
Octavia Wheel Nut Caps
867 601 173 01C satin black (x16) - normal nuts cover
1U0 601 173 01C satin black (x4) - locking nuts cover
Front Suspention Braces
8L9 805 629 A Upper strut brace £48.60
8N0 199 403 B Lower brace £13.20
N 104 679 01 Bolts for lower brace 2x£1.14
N 909 147 01 Captive nuts 2x £2.84
Black B and C pillar trims
KGA 093 008 Estate
KGA 093 006 Saloon
Mk4 Golf Aero Wipers
1J2 955 426B Drivers side blade
1J2 955 425B Passenger blade
1J2 955409 D Drivers arm
1J2 955 410D Passenger arm
Rear Interior Lights
1H0 947 291
NB: These prices were as at 2004. Please post updated prices below plus any additions for this list.
ColinD - 97/100 Limited Edition Octavia vRS < For Sale £2500 Going to Dealers on the 29th...
www.BRISKODA.net :: Site Owner.
E-Mail : webmaster at briskoda dot net
Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views.
ColinD is offline
Old 29-12-2006, 19:48   #2
4x4 Action
will_'s Avatar
Re: Octavia: Useful part numbers for Octavia DIY servicing and mods
Pair of front wipers for Octavia estate:
1J0998003 - SA001E BLADE - £17.39 @ 29/12/2006
will_ is offline
Old 27-05-2007, 17:32   #3
Octavia vRS MK1 Lamda sensor B1S1 (The one before the cat) - AUQ, AUM engines
VW part # 021 906 262 B
Bosch part # 0258007057
Bosch is about half the price. Afther changing the sensor and driving the car about 20 miles the engine management light will turn itself off.
Regards,
Martin
2002 Octavia RS
MartinDK is offline
Old 05-11-2007, 19:02   #4
MAF Air Flow Meter for 110hp Tdi (AHF and probably most other tdi non-pd) is now New style MAF 038 906 461C which is a different and more reliable than the old one. Don't get fobbed off with a B or a X one, the new p/n C one above is the one you want.
greg123 is offline
Old 27-02-2008, 14:11   #5
Bodge's Avatar
Turbocharger divert air valve -N249-
078 906 283 A - £45.79+vat
Diamond Silver '02 Octavia vRS hatch
Bodge is offline
Old 29-04-2008, 13:34   #6
Bodge's Avatar
Intake Air Temperature Sender -G42-
058 905 379 (includes o-ring) - £26.65+vat
(Located on the inlet to the intake manifold)
Bodge is offline
Old 10-11-2008, 15:58   #7
Bodge's Avatar
Coolant temperature sender -G2- (4-pin green):
059 919 501A @ £24.74+vat
[Gasket: N0138115 @ 11p+vat, Retaining spring: 032121142 @ 39p+vat]
Auxillary drive belt (v-belt):
06A 260 849C @ £24.98+vat
Bodge is offline
