octavia vrs 1.8T remap
This is a discussion on octavia vrs 1.8T remap within the Octavia I forums, part of the Skoda Model Discussion Area category; can anyone help? i am a new member and have had my vrs remapped by red dot racing to 196 ...
Old 13-10-2007, 23:58   #1
claytarget_god's Avatar
can anyone help?
i am a new member and have had my vrs remapped by red dot racing to 196 bhp and 202 ft lb. (car was totaly standard)
after about 6 hr of drive time i had a fault on the car on startup.
i did as instructed bey the tech at reddot and disconnected the -ve. this seemed to sort the fault light.
again around 5-6 hr running time, on a cold start the light reappeared.
I then purchesed the cable and VAG com software to see what the fault was and clear it.
it was the mapped engine temp
this fault kept comming back so i took it to skoda for a service and to try sort the prob
they couldnt do any thing as there was no probs with any of the parts.
so i took the car back to reddot and they lowered some of the peramitters. once again 2 days after on a cold start the fault re appeared so i drove 500 mile again to have standard map put back on
the car ran like new and it was ace apart from not having enough power.
friday jus gone i went back again to get another map put on. this one felt not much diff from standard but had a bit more torque and was nice and smooth. the fuel economy was ace too on the drive back to haverfordwest.
on the way i stopped at cardiff for a few hr and went to start the car and all she would do is turn over.
these are the results or the engine scan:
Friday, 12 October 2007, 20:34:40
VAG-COM Version: Release 409.1-US
[b]
6 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16985 - Internal Control Module: Memory Check Sum Error
P0601 - 35-00 - -
17645 - Fuel Injector for Cylinder 1 (N30): Open Circuit
P1237 - 35-10 - - - Intermittent
17647 - Fuel Injector for Cylinder 3 (N32): Open Circuit
P1239 - 35-10 - - - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 - 35-10 - - - Intermittent
17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
P1238 - 35-10 - - - Intermittent
RAC have had a look and said the ECU is broke.
has anyone had a similare experience and what will it take to fix?
also were is the ECU on the mk1 octy?
were can i get the stuff to remap the car myself?
many thanks guys
billy
claytarget_god is offline
Old 14-10-2007, 00:32   #2
Why So Serious
fatty5000's Avatar
Re: octavia vrs 1.8T remap
1st Thing I woud edit out your VIN number on that post
I would try here http://www.briskoda.net/forums/intro...ighlight=16985
Then http://www.briskoda.net/forums/diagn...t-codes/85631/
Just try searching those codes like I have
fatty5000 is offline
Old 14-10-2007, 11:59   #3
cheers
Old 14-10-2007, 17:03   #4
take it to a decent company, someone like Jabba, OK it costs more but you will get it done properly, also they will be getting 220 ish bhp out of it. Sorry but its another case of doing it on the cheap & getting your fingers burnt. If your ECU is fooked a new one is I believe about £600, if you buy second hand you will need someone to burn your security codes onto it, you cant just fit one from another car. Its located behind the wiper blades, remove the wipers & then the black plastic panel behid them & you will find it around cenral in the car.
Speed is an addiction for which thankfully there is no cure
Stuart_J is offline
The Following User Says Thank You to Stuart_J For This Useful Post:
claytarget_god (19-10-2007)
Old 14-10-2007, 17:11   #5
matchmaker's Avatar
Got to agree with Stuart - 192 bhp is far less than I'd expect from a remap. Pre first remap my stock vRS was putting out 188bhp on the rolling road. After the remap (by Star Performance) it was up to 216 bhp.
Alan
"Darth" - Black Magic Octavia VRS with Forge DV, BMC CDA induction kit, Milltek cat, Supersprint exhaust, Xenons, ESP, cruise, parking sensors and Kumho 225/45/17 tyres Been to Star sufficient bhp & ample lb/ft All time low - 7.8 mpg
matchmaker is offline
The Following User Says Thank You to matchmaker For This Useful Post:
Old 14-10-2007, 17:15   #6
Silver bullet
Steevie Wonder's Avatar
A replacement ECU on exchange is around £870........... I had mine replaced 12 months ago
As Stuart has said a quality re-map from Jabba will be well worth it in the long run, even if it's just the generic map for £375ish.
If you keep the car a few years you'll make the money back with the extra fuel economy you'll be getting!!
The silver bulletJabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.
Steevie Wonder is offline
The Following User Says Thank You to Steevie Wonder For This Useful Post:
Old 14-10-2007, 20:34   #7
Oggy's Avatar
Hi, this might be short notice for you, but JBS Autodesign @ Chesterfield have got a 2 for 1 offer available sat 20th Oct on the Custom Code phase1 generic remap. If you can find someone else, either a friend or somebody on the forum to have it done as well, it will work out at about £223 each all in. Thats saving a few pennies & you are gettinga reputable remap. Either that or you might be able to get a price match else where
Oggy is offline
The Following User Says Thank You to Oggy For This Useful Post:
Old 14-10-2007, 22:33   #8
Dont want to point any fingers at anyone but this sounds like a checksumm problem. It is commonly known in the chiptuning world that the ECU in the 180BHP 1.8T uses a later chaecksumm correction than the first 150BHP model.
Anyone not using the latest remapping software with all the paid for updates will have this problem.
If you need it resetting i can do this for you, even with a blocked ECU from incorrect checksumm we can flash this on bench in a few minutes without to much hassle.
yellowcupra is offline
The Following User Says Thank You to yellowcupra For This Useful Post:
Old 19-10-2007, 10:07   #9
thanks all for the info
does this mean I dont need a new ECU?
Old 19-10-2007, 12:11   #10
Liverpool-Lad's Avatar
No, read the post above yours.
2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!
Smiles all 'round
Liverpool-Lad is offline
The Following User Says Thank You to Liverpool-Lad For This Useful Post:
Old 19-10-2007, 13:53   #11
can the skoda mechanics get the car back on the road by using the tools they have in there skoda workshop or does it need more sufisticated equipment?
tis just the griffin mills garage are taking there time and I dont know whats happening as they keep saying they working on it.
has anyone had any experience with griffin mills near cardiff?
Old 19-10-2007, 13:57   #12
Why So Serious
fatty5000's Avatar
Yes I have not the best out there but better than white dove by far
Old 19-10-2007, 14:54   #13
billy, when did you get your car mapped by red dot racing ... is the same company that's based in watford that might have done my map?
im gonna pm you my mobile number please give me a call later tonight if you can as i'd like to discuss this issue with you
baloo247 is offline
Old 19-10-2007, 17:52   #14
remap was back in may on a friday.
by the sun the light came on.
it is so hard to get in touch with the guy who did the map and he doesnt reply to emails either. well not recently.
at first they were polite and friendly even now they were friendly but i am very pissed at the latest problem and i really think he did it on purpose
Old 19-10-2007, 19:41   #15
in may ... hmmm i think i saw your car, i have a silver octavia and i think he was doing your map before he did mine. interesting.
baloo247 is offline
Old 19-10-2007, 20:06   #16
lol
i remember you parked behind the gate.
he mentioned something about tryin a new map on my car and see how it goes to one of his workmates. dont think he knew I was listenin.
Old 20-10-2007, 18:03   #17
car all sorted
cost £150 for the guy at total tuning near cardiff to sort
he knew what he was doin.
cheers
Old 20-10-2007, 20:25   #18
Why So Serious
fatty5000's Avatar
Originally Posted by claytarget_god View Post
car all sorted
cheers
Told you didn't I he's good
Old 21-10-2007, 00:31   #19
Pleased to hear your all running fine again, any idea what he needed to do to get it going? Cheaper than a new ECU anyway!
Is the car back to standard now or running a new remap?
Old 21-10-2007, 23:28   #20
back to standard coz i cant be bothered runnin round if it doesnt work properly. lol
the guy jus re flashed the correct up to date data on to the ECU and fiddled wi VAG com to reacuaint it wi the car, or somethin along thoes lines.
Must say thanks to all who gave me advice on what the prob was and who could sort it.
Old 22-10-2007, 10:36   #21
Site Sponsor
p-torque.co.uk's Avatar
Just noticed this post.
I know its resolved now, but the checksum fault log is 100% an mapping error. When a re-map is carried out, checksumms must be calculated correctly and accurately as the data is altered in the memory
http://www.briskoda.net/forums/signaturepics/sigpic13066_1.gif
VAG Tuning Specialists
CLICK HERE FOR THE P-TORQUE REMAP GROUP BUY!
www.p-torque.co.uk
p-torque.co.uk is offline
Old 22-10-2007, 18:24   #22
cheers for that one mate
do you reacon it was done on purpose?
billy
Old 22-10-2007, 20:01   #23
Why So Serious
fatty5000's Avatar
billy
TBH I can't see a mapping company ballsing up your car on purpose
Old 22-10-2007, 21:17   #24
Site Sponsor
I doubt very much it was on purpose, its usually just a lack of knowledge or mistake
www.p-torque.co.uk
Old 23-10-2007, 00:11   #25
I hope so
jus dint get the impression they like me as i been back 3 times to get it sorted but with no joy
Similar Threads
octavia vrs remap omniped Maintenance & Performance 14 13-08-2007 23:53
