This is a discussion on Octy 1 central locking problem within the Octavia I forums, part of the Skoda Model Discussion Area category; Noticed on Friday that the central locking has stopped working on my o/s/r door. Took the panel off on Saturday ...
| Briskodian Join Date: Jan 2007 Location: west yorks
| Octy 1 central locking problem Noticed on Friday that the central locking has stopped working on my o/s/r door. Took the panel off on Saturday and checked the power supply to the connector and it appears to be okay, so I am assuming that the actuator is goosed. Anyone had a similar problem or got any ideas ![]() ![]() (Just tried the trick of removing the fuse for a few seconds, but it still does not work !!)
__________________ PROTECTING THE PEOPLE OF THIS WORLD FROM THE SCUMBAGS OF THE UNIVERSE !!! |
| Briskodian Join Date: Feb 2007
| Re: Octy 1 central locking problem Central Convenience unit in the door maybe these can play up alot i lost central locking windows and interior lights etc due to water damage cleaned up and 90% working just not interior lights when driver door is open |
| Re: Octy 1 central locking problem Cheers Buddy...not had any water problems or anything similar, and it's just the one lock that's stopped working...anyone got any ideas ??
| Re: Octy 1 central locking problem Same here didn't have any water problems and it all started out with one thing not working the developed from there it was a strange carry on i checked all fuses and un plugged the wiring harness from the ccu to see if any water had got in all looked fine then a few months later the problem got worse so i did the same again and the fuses had blown and the ccu had water damage so i replaced the wiring harness in the door and cleaned the conectors on the ccu unit and it worked again but at first it didn't look like that was the problem maybe worth a look for the 30 mins it would take rules it out anyway - good luck with it |
| Re: Octy 1 central locking problem pull back the rubber boot between the door and the pillar and check for broken wires ![]() |
| Briskodian Join Date: Oct 2006 Location: Swindon
| Re: Octy 1 central locking problem Hi Phillipe, I was also having the similar problem, which is when the sun is shining on to my drivers door, the central locking for it is loosing all power. I also had a bad lock which was a barrel and cylinder, but this one is now fixed. I am not having time as yet to look for my problem, but so you may find this link useful:-http://forums.tdiclub.com/showthread.php?p=666727 There is to be always found some problems with these central locking on drivers door, on this forum. I hope that this will be help for your problem. Soviet Last edited by soviet; 25-06-2008 at 09:11. Reason: sp |
| Re: Octy 1 central locking problem Cheers dudes..it is the rear door that is the problem, and power is getting through, which is what makes me think that it is the actual lock/catch mechanism on the door !!!
| Re: Octy 1 central locking problem Had both driver's side door panels off today, and pulled the relevant (I think) connectors apart, but all seems ok. No corrosion, no water, it all looks like new in there !!! Also checked for broken wires inside the rubber connectors in the door pillars, but again all looks ok. Help !!
| Re: Octy 1 central locking problem Any one got any suggestions ??
| | #10 |
| Re: Octy 1 central locking problem Any one ??
| Central Locking Problem | Yaminchi | Octavia I | 25 | 19-11-2008 20:11 |
| Central locking problem | MattMoore | Octavia I | 0 | 10-02-2008 19:49 |
| central locking problem | wrighs4 | Octavia I | 2 | 23-03-2006 20:50 |
| Help, central locking problem! | helpmedisappear | Maintenance & Performance | 4 | 02-11-2004 21:58 |
| Central Locking Problem? | Alex | Maintenance & Performance | 4 | 14-03-2004 09:24 |
