Octy in for repairs - advice please
This is a discussion on Octy in for repairs - advice please within the Octavia I forums, part of the Skoda Model Discussion Area category; Octy T DI is at the dealers again, after several months of trying to convince them there's a problem. Original ...
Old 16-11-2004, 21:14   #1
bigad's Avatar
Octy TDI is at the dealers again, after several months of trying to convince them there's a problem.
Original symptom was a vibration under load at about 2krpm, and fuel consumption seemed to increase (struggled to get above 50mpg even when treating it very nicely on long cross country runs - in the past have had 64mpg). Eventually got Skoda UK involved and area technical manager, who finally diagnosed problem with dual mass flywheel.
More recently I've been getting what appears to be clutch slip, (and even worse economy!) usually in 3rd, 4th, and occasionally in 5th & 6th from about 2k rpm. Never happens in 1st or 2nd. Flywheel replacement was booked for today, but got a call to say I should keep courtesy car overnight, due to problem with slave cylinder.
I've done 25k in 18 months from new, mostly long trips (motorway and A roads), with the usual weekly town trips. My concern is that whatever has been happening has caused premature wear to the clutch, which as far as I know they don't intend to replace.
Does anyone have any advice on if I should push for a new clutch, on top of the flywheel replacement/slave cylinder fix?
bigad is offline
Old 16-11-2004, 21:33   #2
K44 ENT's Avatar
Definitely would, even if you pay for the new clutch and they supply the labour foc.
Red Octavia vRS
SOLD...Still got the TVR
K44 ENT is offline
Old 16-11-2004, 21:56   #3
bigad's Avatar
Pay for clutch on what basis???
Still have 18 months of warranty left, no mods, serviced by them, and have been telling them that there was a problem for the last 10k miles or so (that they couldn't find!). It just feels wrong to be paying for something that should last, and may have been damaged by a fault covered by warranty.
Clutch should last at least 25k shouldn't it?? My last one was still going strong at 76k (admittedly on a pug 106 diesel ).
Might given them a ring in the morning and find out exactly what the problem with the slave cylinder is. Could failing DM flywheel give the same effect as slipping clutch as described in my original post?
bigad is offline
Old 16-11-2004, 22:03   #4
200 laps.......
i'd push for getting it all free and under warranty,it's not something that should go after 25K,and look closely at the small print on Skoda's warranty the more you know about that the more ammo you have to throw back at them if they try it on.
if your not happy don't accept your car back until you are happy.
Alex
Skoda Octavia vRS-Awaiting Mike at Impossible to sort out STILL
RenaultSport Megane R26 Ultra Blue Number 21
Honda CBR600Fi
WrightyRS is offline
Old 17-11-2004, 09:34   #5
BRISKODA Staff
SkodiRS's Avatar
IIRC, there is a known problem with the slave cylinder and should be changed upnder warranty.
A few members have had this done already.
Adrian.
SkodiRS is offline
Old 17-11-2004, 09:46   #6
Dinosaur
TaviaRS's Avatar
Strange, mine has developed the same vibration under load at 2k RPM. Really noticeable in 6th. Will be interested in finding out what it is.
Either that or I feel a single mass flywheel coming on
A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast.
Official mobile chicane for Briskoda trackdays
TaviaRS is offline
Old 17-11-2004, 11:48   #7
Originally Posted by TaviaRS
it is.
Will that really improve a SDi that much
Speed is an addiction for which thankfully there is no cure
Stuart_J is offline
Old 17-11-2004, 19:01   #8
Cupra Bush King
Lummox's Avatar
Images: 2
I think you will find that a dual mass flywheel comes complete with a new clutch.
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is online now
Old 17-11-2004, 23:13   #9
DGW
BRISKODA Staff
DGW's Avatar
It's the clutch master cylinder which has been modified and is being changed under warranty, Adrian.
Denis
DGW is offline
Old 18-11-2004, 00:54   #10
bigad's Avatar
Slow progress
Quizzed dealer this am, some bits hadn't arrived, so I'm stuck in an Octavia MPI for another day. Horrible, except I'm probably getting better fuel economy out of it than the TDI
Current state of play is; new DM flywheel, slave cylinder, clutch plate. Apparently whatever had been going on had worn the clutch prematurely. Theory was that flywheel problem had affected slave cylinder, causing release mechanism to not operate correctly, causing prob with clutch.
Can't comment on Ross's statement about new flywheel coming complete with new clutch. I'm no mechanic!
Should get it back tomorrow. I'll keep you posted on what they did and what performance afterwards is like.............just need to get remote key fob sorted now.....and no, its not the battery.
bigad is offline
Old 20-11-2004, 11:43   #11
bigad's Avatar
Angry From bad to (drive) shafted
Got car back. Items listed as replaced were;
Flywheel
Slave Cylinder
Clutch Plate.
Picked car up at 5:30pm Thursday, drove 5 miles home.
Left for work at 7:15 Friday am, drove 65 miles to site in the middle of nowhere.
Set off again at 10am to go back to the office
Few miles later (total distance covered since collection = 75 miles), accelerating in 3rd on straight bit of country lane lost drive from N/S (I think), lots of noise and wobbling about (like I'd lost the tyre), dip clutch and pull over (very sharpish). Grease splatter all over engine bay. I'm not a mechanic, but mangled looking bits don't fill me with confidence.
Took 2.5 hrs to get recovered. Told them not to send a van, because it looked horrible. (Was asked if it was drivable by call centre operator, so I said I wasn't even prepared to try.) Patrolman said driveshaft looked pretty much jammed, so we just loaded it up.
Eventually got recovered to dealer (they did take me to dealer which had carried out the work, not the closest, which was good of them).
Looks like CV joint had come adrift. I have my suspicions that it wasn't put back together properly, or at all. All 6(?) bolts were protruding by about 30mm or so. Will now take until at least Tuesday to fix.
On the bright side, I'm still alive, and I'm counting my blessings that I wasn't in the outside lane of the motorway when it happened (Had spent at least 55 miles of journey on the motorway!!!).
I've also got a new octavia 2.0 140bhp to use until then. Its pretty good. Drives like its meant to, does 55mpg even when driving "normally" without even having to try, pulls like a train etc etc. Everything mine doesn't.
To be honest I'm dreading getting mine back now. Am now weighing up my options for tackling Skoda.
bigad is offline
Old 20-11-2004, 13:50   #12
logiclee's Avatar
I would say its almost certain they didn't put it back together correctly.
Lee
Another Ex-Scooby owner.
Mondeo TDCi 130 6 Speed Ghia, Octavia 1.9TDi Elegance (Now Sold), Fabia 1.9TDi Comfort and Felicia 1.9D GLi
logiclee is offline
Old 23-11-2004, 23:00   #13
bigad's Avatar
Unhappy Update
Octy was due back today, but apparently they haven't got the torque settings for wheel end of driveshaft or something..... (only on 130BHP TDI.)
Queried them about poor fuel economy, considering that I can easily get 60mpg out of the 140BHP new octavia I'm using, on my normal commute (first done today, 64.5mpg). In my heap I can only manage 52mpg if I take it really easy and with climate control on econ. Was fed a story about the new 2.0 engine being completely new and improved, with much better economy, hence the difference. Just checked on skoda.co.uk and that appears not to be the case.
130bhp(estate)
urban 39.2
Extra U 61.4
Combined 51.4
140BHP (new hatchback)
urban 37.2
Extra U 56.5 !!
Combined 47.9
Getting more confused all the time.
Has anybody else got a 130BHP Elegance estate with any real world economy figures? Failing that, Fabia vRS figures, there must be lots of you, and some who take it easy occassionally
I've got a feeling that there's an underlying problem, but no way to prove anything.
bigad is offline
Old 23-11-2004, 23:03   #14
Cupra Bush King
Lummox's Avatar
Images: 2
Sounds like someone didnt tighten a drive shaft flange on the gearbox up to me, very poor show.
www.unit18.co.uk
Old 23-11-2004, 23:54   #15
bigad's Avatar
Sounds like a good explanation
I'm no techie, but that could quite possibly be the cause. Are there approx 6 bolts on the flange? All the ones I could see were protruding (ie thread visible).
Do you have any thoughts on how serious the consequences could have been if the failure had happened at speed? Had done at least 50 miles at motorway speeds.....In one way I'm feeling pretty lucky. On the other hand I'm fuming.
bigad is offline
Old 23-11-2004, 23:57   #16
Cupra Bush King
Lummox's Avatar
Images: 2
You wouldnt be in any danger, just lost drive as you know, the driveshaft cant go anywhere just would bash about and create further damage.
Id make sure they check over the shaft properly.
www.unit18.co.uk
Similar Threads
Octy vRS 1st service + Fabia vRS test drive SUTTS General Car Chat 2 30-04-2005 10:43
Help! Octy Vrs vs Furby Vrs stokey General Car Chat 11 17-11-2004 17:08
Octy Vrs V Fabia Vrs Dual !! Pot herb Off Topic and Chit Chat 15 22-08-2004 09:06
Tyre advice Octy RS garkov Maintenance & Performance 35 12-05-2004 08:37
