Octy Vrs Cruise control
This is a discussion on Octy Vrs Cruise control within the Octavia I forums, part of the Skoda Model Discussion Area category; I am having trouble with my cruise control, It started when the ecu was loaded with the wrong checksum and ...
Old 29-11-2007, 23:36   #1
claytarget_god's Avatar
It started when the ecu was loaded with the wrong checksum and wouldnt start. (I had a map loaded on in london and drove back to cardiff were it worked fine till I stopped the car for a few Hr and it wouldnt restart)
I had skoda look at it and they couldnt sort it in time so A member gave me the name of a guy that could fix it. he took ecu out and put the correct software on so the car ran. I never thought aut of it till I drove all the way home were I tried to use cruise and nothing works.
does anyone have any Ideas on what it could be?
is it something to do with the ecu?
billy
claytarget_god is online now
Old 29-11-2007, 23:51   #2
Txt Spk Police
VRStu's Avatar
Re: Octy Vrs Cruise control
It might need the cruise enabled again.
It can be done with VAG-COM if that is the problem.
Stu
VRStu is offline
Old 30-11-2007, 00:12   #3
lol cheers how do I do that? I only got the 401 version. can it be done with it?
cheers mate
Old 30-11-2007, 08:02   #4
Txt Spk Police
VRStu's Avatar
Not sure but you can try.
Open Cont 01 - Engine and then select login and type in 11463 and then do it.
Stu
VRStu is offline
Old 30-11-2007, 21:24   #5
I have found that a blown brake light or a door left ajar will also stop the cruise working!!
01 Octavia 1.8T Elegance 4x4 Estate Cruise control, Selca Cat 1 Alarm Immobiliser
04 Nissan X-trail Dci SVE
Naythan is offline
Old 30-11-2007, 21:29   #6
mmm cheers for the info mate, Dont think it is that coz lights all work fine and the door sensors say they are shut. I wish that it was that simple lol
Old 30-11-2007, 21:41   #7
Why So Serious
fatty5000's Avatar
Doesn't the brake pedal switch need to be tip top as well for cruise to function.
Just a thought ....HTH
fatty5000 is online now
Old 30-11-2007, 21:42   #8
Txt Spk Police
VRStu's Avatar
If the Brake Pedal switch (very common failure) has failed then the CC won't work.
VAG-COM scan is your best bet.
Stu
VRStu is offline
Old 30-11-2007, 22:35   #9
mmm Was thinkin about the pedal switch, I have done a scan and no faults were detected??????
Ill have another look tomoz and see...
cheers fellas for all the tips
Old 30-11-2007, 22:44   #10
Txt Spk Police
VRStu's Avatar
You could try looking at the MBV for the CC Stalk and see if it is operating. You can also check the Brake Pedal Switch.
Stu
VRStu is offline
Old 30-11-2007, 22:52   #11
Txt Spk Police
VRStu's Avatar
Look at Group 66 in Engine 01
I think it'll look like this on your 1.8T.
066,0,Electronic Throttle (Cruise Control System)
066,1,Vehicle Speed,(current)
066,2,Switch Positions I,,See Label File
; xxxxxxx? = Brake Light Switch
; xxxxxx?x = Brake Pedal Switch
; xxxxx?xx = Clutch Pedal Switch
; xxxx?xxx = CCS (Cruise Control System) enabled
; xxx?xxxx = ACC (Adaptive Cruise Control) available
; xx?xxxxx = Main Switch engaged
; ??xxxxxx = CCS Status
066,3,Vehicle Speed,(specified)
066,4,Switch Positions II,,See Label File
; x0xxxxx? = CCS ON (CAN)
; x0xxxx?x = SET (CCS ON)
; x0xxx?xx = Deceleration (-)
; x0xx?xxx = Acceleration (+)
; x0x?xxxx = SET
; x0?xxxxx = RESUME/RESET
; ?0xxxxxx = CCS ON (Hardware Pin)
Stu
VRStu is offline
Old 10-12-2007, 00:17   #12
cheers for all the info fellas
jus been home for the weekend and pluged in Vag Com
all i did was login to the engine and changed the WSC number and for some reason it now works lol
I am well chuffed
cheers again
Old 14-12-2007, 14:30   #13
IS cruise control standard on the vrs because im sure i havent got it???
Just me being thick i suppose???
h1gg1 is offline
Old 14-12-2007, 14:39   #14
Txt Spk Police
VRStu's Avatar
No not standard.
Stu
VRStu is offline
Similar Threads
Octy 1.9Tdi DSG Elegance - Cruise Control Retsef Octavia II 5 24-07-2007 12:35
Cruise Control Octy 1 vRS thomj42 Octavia I 18 24-05-2007 10:34
Vrs - cruise control steve65 Fabia I 4 06-11-2006 23:40
Cruise control for Fabia vRS magnum67 Fabia I 22 14-09-2005 22:50
Octy vRS Cruise Control Problem ventmore Maintenance & Performance 16 15-09-2004 13:26
