This is a discussion on Octy VRS not selecting gears within the Octavia I forums, part of the Skoda Model Discussion Area category; Worked fine yesterday........got in it today and could not select reverse, just crunching. With a bit of effort I could ...
| Briskodian Join Date: Oct 2003 Location: Cambs
| Octy VRS not selecting gears Worked fine yesterday........got in it today and could not select reverse, just crunching. With a bit of effort I could find the forward gears. Turn engine off and start it up in reverse and this worked but you could feel the clutch dragging. Clutch pedal travel and feel is normal. Managed to get it to the garage...........will have to wait and see what they come up with but there were mutterings about a clutch change and not covered by warranty. Car has only done 42K miles and I have never had a clutch go before 135K miles. Anyone have any experience of this or similar fault? What was the outcome? Thanks Chris
__________________ 255BHP + 321Nm and climbing |
| Briskodian Join Date: May 2004 Location: Hampshire
| Pulling 250 plus brake are you not surprised uprated clutch i think is the way forward ![]() |
| Briskodian Join Date: Oct 2004 Location: Bracknell, Berkshire
| I would suspect it's the clutch. I would have thought the clutch on any turbo car with IRO of 200bhp would go around 50k miles. Although, a lot does depend on how you drive.
__________________ 2005 Skoda Octavia vRS Hatchback - Black Magic Pearl |
| Well the plot thickens.........clutch has been checked......fine.. only very slight wear. Pressure plate etc all looks okay........garage doing some head scratching now!!!
| Briskodian Join Date: Oct 2004 Location: Cleethorpes
| Mine went in the same way! Clutch release plate was the cause! New clutch on warranty thanks! |
| i would've thought a shagged clutch, sounds exactly like mine went before it totally gave up. have you heard and funny noises?? grumbles or whines?
| I couldn't get reverse, but could get all the others! Not much use when your facing a wall! New clutch sorted that out! No catastrophic failure and no sign of one either! |
| mine was screwed, it was actually the thrust bearing that started it all off. that went tits up which put more stress and heat onto the clutch which aged it very quickly, could also see heat stress on the pressure plate and fly wheel
| | #9 | |
| Quote:
C
__________________ 255BHP + 321Nm and climbing | |
| National Briskoda Trackday | delcac | Shows | 410 | 12-03-2004 15:21 |
