This is a discussion on octy vRS tuning. within the Octavia I forums, part of the Skoda Model Discussion Area category; Where sould i start???? The re-map will be left to the end so as i only have to do it ...
| Briskodian Join Date: Jun 2006 Location: Ely, Cambridge.
| octy vRS tuning. Where sould i start???? The re-map will be left to the end so as i only have to do it once. but what to do in the meantime and in what order...? TIP. FMIC. CAI. Exhaust & sports cat. Suspension & brakes. . Anything i've missed? . What are your thoughts.......... ![]()
__________________ My other Skoda's a Nissan.... |
| A Nice Guy Join Date: Jun 2006 Location: Sheffield
Images: 1 Thanks: 93
| Re: octy vRS tuning. Hi mate Im in a similar predicament but have decided to go this route Upgraded recirc valve DV30 just fitted next is CAI then exhaust and sports cat then remap and FMIC that should do but there is always big turbo upgrade, nitrous and various other ways to extract more power, but you start talking huge amounts of money
__________________ |
| Briskodian Join Date: Apr 2006 Location: Sheffield
| Re: octy vRS tuning. CAI or Panel (i went green panel) TIP Zaust FMIC remap DV if you want to of if it recommended like some do Of course thats all done after your cam belt and water pump change aint it crap i know as my last service was half a full miltek system but thats lifeSuspension id go for S3 lower strut R32 ARB Brakes Super 4.1 fluid DS52000 pads job done |
| Re: octy vRS tuning. Good so far, keep 'em coming... . Of course there is also the burning question of.... Blue flame, Milltec, other...etc... . ![]()
| Re: octy vRS tuning. I just went for a remap plus Bailey DV, then added Jabba's variable boost controller later. Amazing value and performance for the money. ![]()
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Re: octy vRS tuning. You'll want the full turbo back exhaust system including the cat. 100cel although most Millteks come with the 200cel.....100cel should be fine.....mine has an IHI turbo, 3'' dp and 100cel and went through the MOT emissions test no problem. Which CAI are you thinking of and why? If you're just after sound then fine but beaware CAI will give minimal increase and some may even reduce power. DV - latest OEM DV are fairly good now and respond quicker than piston type aftermarket products. Check out the Forge Eliminator which is a diaphragm type..as per OEM...but better quality. An alternative to the FMIC is a intercooler spray.....sprays water from washer bottle onto intercooler....works well. Or perhaps water injection e.g Aquamist. If you want to eventually go big turbo route...forget the turbo back exhaust system and get a cat back...purely for sound...as big turbo will generally require a 3'' dp and cat. Also you wouldn't be able to reuse the TIP and there may be some connection issues with the CAI depending on the size of MAF used.
__________________ Adrian. |
| | #7 | |
| Briskodian Join Date: Jun 2005 Location: NW Kent
| Re: octy vRS tuning. Quote:
Exhaust next. The CAI sounds good & it's cheap enough. TIP is a good mod but slightly more expensive. FMIC is 600 odd nuts, I'm told it makes a differance, I've got one & I'm not convinced it's worth the money! You've done the right thing by asking ![]()
__________________ Deli G ,,,, leader of the Peckham Massif! KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted. Was that a 4x4 Skoda??? It's IMPOSSIBLE! 197.2 BHP & 263.1Nm | |
| Re: octy vRS tuning. As far as the zorst is concerned i will be going for a full (2.5" downpipe) system and sports cat anyway, was more interested in quality/price. Also does the centre silencer make much difference to power or is it just a noise thing? . I am thinking along the lines of Jabba's style of CAI but with green cotton filter (from an aesthetics viewpoint) as i'm just not sure i trust having the filter down in the headlight area... each to their own i suppose. . already have a Bailey's DV30. . Big turbo is not an option for me, i just want a bit more oomph (technical term) and will prob' be looking at a mk2 octy vRS in a few years time. . Having had the car for a few months now and fitted my boost gauge i can now (ALMOST certainly) say that on hotter day's the boost is cut by 2-3 psi and the car has less pull which must be related in part to charge temp's? Hence the possible FMIC route. . Ah well, best start saving.......... ![]()
| Briskodian Join Date: Feb 2006 Location: Hawick,Scottish Borders
| Re: octy vRS tuning. what did you pick to do first mate and what do all the abbrevations mean im new to this tuning jobLast edited by swany; 15-08-2006 at 20:34. |
| | #10 |
| Re: octy vRS tuning. TIP is a 'turbo inlet pipe' after market ones from tuners are larger with better flow. FMIC is a 'front mount intercooler' larger and more efficient than the teeny-weeny-tucked-down-one-side standard one. CAI is a 'cold air indiction' kit usually in the form of a cone filter with a cold air feed tube from the front of the car ar a filter on the end of a long inlet tract (i.e. filter near the front of the car. I will probably go for the remap first as i have now found somewhere that will 'tweak' the remap charging accordingly and not have me shell out for another full remap. That way i can add exhaust etc later. Brakes and suspension will get done when they need replacing unless i find i NEED them due to performance.
| | #11 | |
| Briskodian Join Date: Jan 2004 Location: Up a tree.
| | #12 |
| Re: octy vRS tuning. Always start tuning with the brake upgrade. It's too late to find out that you need it when you've just cooked them and are catching a polis motor at a rate of knots! |
| | #13 | |
The filter is by JR and is very lightly oiled....mine make s nice induction noise and the DV can be heard even on the motorway...ask Nick (ncarring) about mine "psth"ing at 80mph. My Jetex has a centre box and a huge rear box...probably why it's fairly quiet in comparison. DaveU had a Powerflow cat back with a small rear box...was louder than my set-up now. Removing the cat also makes a big difference in sound. You will most notice a FMIC in hot weather....boost will be held much better....also you can have the car mapped to take the FMIC into consideration and give more boost. Like said earlier it's worht having a look at the SMIC water spray or water injection...particularly if you're not going big turbo route...Jon used a SMIC spray and found it very effective on track days. They cost approx40-50% of a FMIC.
__________________ Adrian. | |
| | #14 | |
| Briskodian Join Date: Jun 2004 Location: West Yorkshire
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport | |
