Octys back in again
This is a discussion on Octys back in again within the Octavia I forums, part of the Skoda Model Discussion Area category; Took Octy in to Skoda again Saturday just gone After they fixed my gearbox and clutch iv now a new ...
Old 11-08-2008, 20:43   #1
k04
k04's Avatar
Octys back in again
After they fixed my gearbox and clutch iv now a new problem
With steering on full lock i get loud clanging noises coming from drivers side,turns out one of the coil springs have snapped
Iv no idea how this has happened coz the cars not driven as if its a Land Rover
They said it should be covered on warranty,just got to wait til Thursday when they get the part in
Has this happened to anybody else,can they just break like that? The cars just touched 47k
CarbonioCAI - Forge Splitr dv - Leon CupraR Splitter - Black grille surround -
To do: Turbo back Exhaust and remap (hopefully sometime)
Black Magic V r s 187.2bhp
Andy
k04 is offline
Old 11-08-2008, 20:55   #2
mbames's Avatar
Re: Octys back in again
Seems to be quite common - they break off an inch or two from the end..... My springs are still original ones (2001) and have covered 125k - maybe I am lucky!!
mbames is offline
Old 11-08-2008, 20:58   #3
Bored!
jaymd's Avatar
Make sure they replace both springs on the front not just the broken one.
jaymd is online now
Old 11-08-2008, 21:01   #4
k04
k04's Avatar
Just seems odd,none of my other cars have had this happen
Andy
k04 is offline
Old 11-08-2008, 21:07   #5
Bored!
jaymd's Avatar
It is common.
jaymd is online now
Old 11-08-2008, 21:13   #6
k04
k04's Avatar
I'll ring em tomorrow to get both replaced
Andy
k04 is offline
Old 11-08-2008, 22:18   #7
vRS_Si's Avatar
Yeah I had one go a few years ago.
Skoda would only replace the one though
vRS
Mirror polished 9*18" Mercedes Alloys, APR FMIC, ABD TIP & CAI, Powder coated inlet manifold, Jabba Re-map, Blueflame/Pipewerx exhaust, Forge DV, KW v3 coilovers, Neuspeed ARB, S3 strut braces, bonnet lifters, Autostyl rear spoiler, Milotec rear diffuser & bumper grills, side rubbing strips removed, front and rear rubbing strips smoothed and colour coded, scuttle pannel colour coded, chrome grill colour coded, mk2 vRS badge, de-locked, tints, mk4 aero wipers.
vRS_Si is offline
Old 12-08-2008, 00:14   #8
Coops-Octy_vRS's Avatar
yep, had it happen last year, coming back thru New Forest at night road junction suddenly appeared and under braking just happened to hit a bump/rut in the road at same time, so i knew mine had gone. well, didn't know what it was til i got it into the garage, didn't seem to affect generally driving apart from a knocking noise on full lock.
i only replaced one as well, but's that's because all i could afford at time, and it was out of warranty, happened at 55k ish and 18 months and over 10k later not had any issues with one i didn't replace.
Paul
'01 Octavia vRS
Coops-Octy_vRS is offline
Old 12-08-2008, 01:00   #9
BJM
Mine went at about 58k after hitting one of those plastic type "speed bumps" in a dark car park at about 10 mph - saw it at the last minute and was braking hard.
Get them replaced as a matching pair - the "old" one will have compressed and lost some tension from 50k miles of being used.
BJM is offline
Old 12-08-2008, 21:06   #10
k04
k04's Avatar
Looks like it is quite common then,im not the only one
Bloody cars a!
Andy
k04 is offline
Old 12-08-2008, 22:05   #11
One of mine went recently on a 34k mile car.
Get new strut top mounts and bearings done at the same time and save on labour. Its only about another £40 in parts , and the bearings are known to seize up as well.
Steve
_______________________________________
a1topdog is offline
Old 13-08-2008, 12:36   #12
JRHartley's Avatar
Mine went last year. The top coil snapped off and the spring went up over the top mounting. Had to get spring compressors on the spring to re-compress it before I could lower the spring/damper assembly out of the car. Pain in the **** to use the compressors in such a tight space but I did it.
Had to replace a rear one the year before that. It had lost less than 1 inch at the bottom [the taper bit where the spring meets the bottom plate] but the MOT tester failed it. He said it must have only just happened as the metal was still bright and thats what caught his attention....fck*** *g sods law....
IMHO the springs used on the octy are sh1te and just not upto the job. Two springs on this car and never had to replace one on any other car I've owned. The only issue I've ever had with the octy. Can't fault it otherwise.
I'm a celebrity...... Get me out of here !!!
JRHartley is offline
Old 16-08-2008, 10:01   #13
k04
k04's Avatar
Got car back last night
All is well,i hate it when you havnt got your car coz its in the garage or whatever
I filled her up with 99ron and took it for a well deserved spin
iv missed it
Andy
k04 is offline
Old 02-09-2008, 20:19   #14
My rear one snapped about 2" from the end 4 weeks ago, just short of 80k. only just got a replacement rear pair delivered this week.
OctaviaBuzz - '02 Octavia 1.9SDi
Current Status: 82k miles, currently averaging 51.5mpg
My dry weather transport - CBF600N
OctaviaBuzz is offline
Similar Threads
Octys Offroad? Obadiah Octavia II 11 17-06-2008 16:53
my octys new look pk06 Octavia II 25 28-05-2008 00:42
My octys sick CHRIS ELLIS Octavia I 13 14-05-2006 11:00
Do Octys come prewired for cd changer? winx ICE, Security and Insurance 1 02-01-2006 21:33
Some cheap new Octys here Stuart_J General Car Chat 0 11-10-2005 09:01
