This is a discussion on Oil change help needed within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi I'm servicing my car tonight, changing the cam belt, and changing oil. I have a 1.8t 4x4 with the ...
| Briskodian Join Date: Oct 2005 Location: Littleport
| Oil change help needed Hi I'm servicing my car tonight, changing the cam belt, and changing oil. I have a 1.8t 4x4 with the ARX engine. It is on Variable servicing. i have been to Halfords, and thier book states I should use a 5w-40 I have also looked at this table http://www.skoda.co.uk/skoda3g/conte...mmendation.pdf and It seems to say I need 0W-30 Please help someone must know the correct oil. Thanks |
| Re: Oil change help needed Sorry for putting this up again, just I have not had any replies yet!! I also have it re-mapped too if that's important Pleas help!! Also where can you get Haldex oil other than at Skoda?? |
| Re: Oil change help needed Halfords are wrong. You need a spec VW 503 00 oil for variable service intervals. This is an 0W-30 fully synthetic oil. The FAQ on this subject is currently missing, but here is an oldish list of suitable LongLife oils: Aral SuperTronic LongLife II SAE 0W-30 BP Visco 7000 LongLife II SAE 0W-30 Castrol Longlife 2 Top Up SAE OW-30 Castrol SLX LongLife II SAE 0W-30 Elf Evolution CRV SAE OW-30 Esso Universal LD SAE 0W-30 Fuchs Titan Supersyn SL Longlife Plus SAE 0W-30 Q8 Formula Excel EDX SAE OW-30 Mobil SHC Formula LD SAE 0W-30 Motul Specific 50601 50600 50300 SAE OW-30 Shell Helix Ultra X SAE 0W-30 Texaco Havoline Synthetic 50601 SAE OW-30 I have been using the version of Castrol SLX LongLife II which includes that spec plus 506 00 and 506 01. But be aware that Castrol also make a version of that meeting spec VW 503 01 - this is not suitable for your car. You should be able to get Haldex oil at any VAG dealer. You will need to use VAG-COM sftware (or a dealer) to reset your car for variable servicing.
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... Last edited by DGW; 15-03-2006 at 10:45. |
| Re: Oil change help needed Thanks for the help on that, thought they were wrong!!! Cheers. |
| | #5 | |
| Skudmunki Join Date: May 2003 Location: Northwest
| Re: Oil change help needed Quote:
__________________ http://www.sloganizer.net/en/] ![]() Diamond Silver 54 Octy vRS Mk1, 18" TT Quattro Black / Polished rims, 225x40x18 Goodyear F1 GSD3,a Forge FMIC, Forge Eliminator DV , 4bar FPR, HID Hi/Lo Mains and fogs, LED purewhite LED Sidelights, HID Fogs, Silvervision Indicator bulbs all round, Headlight protectors... | |
