Oil Change and which oil?
This is a discussion on Oil Change and which oil? within the Octavia I forums, part of the Skoda Model Discussion Area category; I was looking at getting an oil change on my 1.8T 4X4 and wanted some high quality oil any suggestion ...
Old 01-08-2006, 20:53   #1
Thumbs up Oil Change and which oil?
I was looking at getting an oil change on my 1.8T 4X4 and wanted some high quality oil any suggestion and places to buy. Also is the oil change straight forward or is there a specific technique? I know the question seems daft but the last Skoda I had within a week of getting an oil change done at an 'Independant Garage' the car finally gave up on me (after loads of other problems) and 'The Car People' finally gave me a refund (not full refund of course!!!).
Any advice would be greatly appreciated.
Aaquil
Aaquil is offline
Old 01-08-2006, 20:56   #2
Cupra Bush King
Lummox's Avatar
Images: 2
Re: Oil Change and which oil?
Whilst your down at the VAG garage getting your genuine oil filter Get yourself a 5L can of Synta Gold oil made by Quantum (its kinda budget VAG stuff) and its pretty darn cheap, also very good.
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is online now
Old 01-08-2006, 21:03   #3
NascarMike's Avatar
have you tried the website www.opieoils.co.uk, I bought some Fuchs Oil VW 507 00 specification for about £34 about 2 months ago, this is a fully synthetic oil, to the latest VAG specification, and was about a tenner cheaper tham the castrol variety at Halfrauds
Apparently Fuchs Oil work very closely with VAG and it is top notch oil.
Contact Opie oils if I was you, service is excellent, prices good, they will recommend an appropriate oil for you as well and give you a discount for being a Briskoda member
NascarMike is offline
Old 01-08-2006, 21:37   #4
Ta moko!
RobClubley's Avatar
I need to do mine soon. I have the filter and oil ready
Silly question - how do you get to the filter to change it?
It looks like it'd be a sod to get out!
Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand!
Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge
www.pimpmyskoda.co.uk www.clubley.org Facebook
RobClubley is offline
Old 02-08-2006, 17:44   #5
Thanks guys for the advice so my friends at RE Performance Bury will have no problems doing the oil change for me then? What is the oil capacity of the engine?
Aaquil is offline
Old 02-08-2006, 18:43   #6
richm's Avatar
yep, Guy and Simon are great guys to deal with, you will get proper genuine knowledgeable advice from these guys, and ultimately they will offer best advice but equally, sell you whatever you want.
richm is offline
Old 02-08-2006, 22:30   #7
MC Bodge's Avatar
The Octavia is the easiest car I've ever changed oil for. The filter is in an easy to grab position. It may be on very tight though!
Mk1 Octavia vRS. The thinking man's Hot Hatch.
PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close
MC Bodge is offline
Old 02-08-2006, 22:33   #8
Ta moko!
RobClubley's Avatar
Good news - obviously not as bad as I thought. Presumably you grab it from underneath the car?
As you might have guessed this will be the first oil change I've done myself
Old 03-08-2006, 00:22   #9
cheezemonkhai's Avatar
I like the TDI oil filter position, looks to be a pull out drop in job on the top
cheezemonkhai is offline
Old 03-08-2006, 09:28   #10
mbames's Avatar
I thought I was never going to get mine off the TDi - had to grip the plastic housing with a sandpaper and a chain wrench.... It had been done up by a monkey and his friend... twice!
mbames is offline
Old 03-08-2006, 16:45   #11
Just ordered some of the Silkolene Pro S 5W-40 from Opie Oils spoke to both Simon and Guy. Polite, helpful and efficient the order took a matter of a few minutes. Defo recommend.
Aaquil
Aaquil is offline
Old 03-08-2006, 20:05   #12
So how did you tighten it back up to the required torque?. My socket set didn't have the jumbo socket needed .
benterrier is offline
Old 03-08-2006, 20:36   #13
richm's Avatar
Aaquil
Pro-S is the best oil available at the price IMO - use the same in my cosworth sierra, track use included, and maintains hot pressure under the most arduous conditions.
richm is offline
Old 03-08-2006, 23:30   #14
mbames's Avatar
Just did it back up by hand....!
mbames is offline
Old 04-08-2006, 09:32   #15
mattbeef's Avatar
ive always done it as tight as i can by hand then a quarter turn by chain ratchet
I few bits here and there but im happy to Performance Torque
Go on click me you know you want to
mattbeef is offline
Old 06-08-2006, 23:43   #16
Thanks for that Richm.
Aaquil is offline
Old 06-08-2006, 23:50   #17
EddyH's Avatar
I use Synta Gold in mine, also don't forget the sump plug washer (assuming you are doing the oil change the traditional way).
EddyH
Audi A6 Avant 2.7 TDI
Audi A3 2.0 TDI Sport
EddyH is offline
Old 09-08-2006, 23:07   #18
Thanks Eddy got it all yesterday doing it at RE Performance Bury on Saturday. I just replaced the air filter and the car seems to be going better or is it just my imagination?
Aaquil is offline
