This is a discussion on Oil leak from 1.9 TDI 90 BHP engine within the Octavia I forums, part of the Skoda Model Discussion Area category; I have found an oil leak in the air filter - engine hose of skoda octavia 1.9 TDI engine. Please ...
| Briskodian Join Date: Sep 2007
| Oil leak from 1.9 TDI 90 BHP engine I have found an oil leak in the air filter - engine hose of skoda octavia 1.9 TDI engine. Please refer the attached picture. Is there anything serious? Please help Last edited by palival; 11-08-2008 at 10:20. |
| Re: Oil leak from 1.9 TDI 90 BHP engine The photo's helpful. That's one of the crankcase (well more like the cam cover actually from the photo) ventilation hoses. If there's oil leaking out of it, then there will be air leaking in, so it needs replacing for best running. If there's oil inside it leaking into the main air feed, that may or may not be ok. It depends on how much, and what sort of mileage your car's done. |
| Re: Oil leak from 1.9 TDI 90 BHP engine After some research I have found the exact oil leaking part. It is pcv valve ( Positive Crankcase Ventilation valve) that ensures continual evacuation of gases from inside the engine. |
| Re: Oil leak from 1.9 TDI 90 BHP engine If oil's coming out of that over the outside of the engine, it needs replacing. |
| Re: Oil leak from 1.9 TDI 90 BHP engine No..The valve itself leaking. No oil leak from the engine. Still need to replace pcv? |
| Re: Oil leak from 1.9 TDI 90 BHP engine Where is the oil going? If it's coming out of the valve over the outside of the engine, then the PCV valve is leaking. If it's going into the intake duct, that might be normal operation, but whether it is or not depends on quantities. VAG report up to 1l / 1_600km (1_000 miles) as being "normal consumption". If there's been a significant increase in oil consumption recently, I think you've identified why. |
| Re: Oil leak from 1.9 TDI 90 BHP engine I have checked again in the engine bay. The oil is dripping from pcv valve breather pipe end which connects to air intake. Please refer the picture. The oil is dripping on the backside of the engine. But i haven't noticed any increase in oil consumption. It might be a slight leak only. |
| Briskodian Join Date: Oct 2006
| Re: Oil leak from 1.9 TDI 90 BHP engine Is there an actual valve in it isn't it just a pipe connection for the breather. |
| | #9 | |
| Re: Oil leak from 1.9 TDI 90 BHP engine Quote:
After that, clean up the hose, valve and where it's dripped, and keep an eye on it. If it's still dripping it ought to be replaced, but there's no urgency for it. | |
| The Following User Says Thank You to KenONeill For This Useful Post: | palival (12-08-2008) |
| | #10 |
| Re: Oil leak from 1.9 TDI 90 BHP engine Ok..I will do that. Thank you guys. |
| Octy tdi crank-case oil leak | dskoda | Maintenance & Performance | 8 | 03-12-2007 09:46 |
| Fabia 1.4 TDI oil filler leak | fergusgorman | Fabia I | 2 | 17-06-2007 18:56 |
| Improving BHP on 90 BHP TDI Engine | SKOD | Octavia I | 3 | 04-04-2006 15:01 |
| Octavia TDI 2001 Rocker Cover Oil Leak | raysuz | Octavia I | 1 | 27-03-2006 22:15 |
| Difference between fabia 130 Bhp RS engine and 101 Bhp TDI | Cybfox | Maintenance & Performance | 44 | 23-03-2004 20:58 |
