Oil Pressure
This is a discussion on Oil Pressure within the Octavia I forums, part of the Skoda Model Discussion Area category; Can anyone tell me roughly what the Oil Pressure should be on an Octy vRS. I have finally manage to ...
Old 10-04-2005, 20:26   #1
Oil Pressure
Can anyone tell me roughly what the Oil Pressure should be on an Octy vRS. I have finally manage to fit the sender unit and hook it all up. My pressure rises as i accelerate from around 80psi to anywhere up to 98psi. Is this normal or is my equipment shafted?
Marki is offline
Old 10-04-2005, 20:44   #2
Still a ****
delcac's Avatar
Is it at 80psi at idle.
The Red Devil
delcac is offline
Old 10-04-2005, 21:16   #3
Yep! There or there abouts.
Marki is offline
Old 10-04-2005, 21:48   #4
fastVeRSion's Avatar
Hi mate, I still haven't sorted my oil pressure gauge (had a bad back, so haven't been able to sort it properly - done oil temp and boost gauges tho).
Anyway, when i attempted it i couldnt get the connector off the original sender. Can I ask how it comes off so i know when i get back to doing it?
Cheers.
Dave J
2002 Octavia vRS
Golf R32 Steering Wheel, Gauges from 42DraftDesigns, Noise by Blueflame
fastVeRSion is offline
Old 10-04-2005, 23:01   #5
I went in at point 10 on the attached linked diagram. Had to buy a long socket shaft extension to reach. Covered the screw in WD40 and used a 5mm allen key attachment. had to bend out a couple metal stems that hold wiring but after that was not to bad. Cut my hands to shreds though so go careful.
http://www.42draftdesigns.com/oil18t.htm
Marki is offline
Old 11-04-2005, 20:48   #6
Bloomin flip! Thats what i thought you'd say!
Thats where my oil temp sender has gone (no 10), so i cant use it. I need to remove the old sender (No 16), and i've ripped me hands to bits without even getting the connector off it!
Thanks anyway
Dave J
2002 Octavia vRS
Similar Threads
How to: Change the Engine Oil and Filter (Fabia vRS) aixlad Technical Guides 15 20-10-2008 22:31
Modded your Skoda? Some Oil Advice! oilman Maintenance & Performance 82 11-10-2004 12:09
Oil Pressure Sensor Location. Monkey Boy Maintenance & Performance 3 18-06-2004 20:35
Oil Pressure Sensor Locations TaviaRS Maintenance & Performance 15 30-07-2003 18:59
