This is a discussion on Oil temp sender mounting? within the Octavia I forums, part of the Skoda Model Discussion Area category; I assume that fitting the oil temp sender is easiest by using the sump plug hole somehow? It looks as ...
| Briskodian Join Date: Dec 2005 Location: North West England
| I assume that fitting the oil temp sender is easiest by using the sump plug hole somehow? It looks as if the thread would a bit small to be a direct replacement (although I've not compared it with the existing sump plug) What's the best way to attach it? ps I'm planning to change the oil soon anyway so would need a new plug.
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close |
Images: 2 Thanks: 22
| Re: Oil temp sender mounting? Easiest way is to get a double take off for the oil pressure switch, be a bit safer than hanging off the bottom of the engine aswell.
| Re: Oil temp sender mounting? cheers, I'll have a look to see if I can find it. I'm new to the 20VT engine and having no workshop manual means a bit of guess-work and as many hints as I can!
| Briskodian Join Date: Nov 2003 Location: Hull,East Yorkshire
| Re: Oil temp sender mounting? Check out this page http://www.42draftdesigns.com/instal...k1_oil1.8t.htm i picked my oil temp up from there and it works fine ![]() |
| Re: Oil temp sender mounting? Thanks for that useful site! That looks straight-forward enough.
