This is a discussion on The old hesitation after remap problem within the Octavia I forums, part of the Skoda Model Discussion Area category; I know this problem has been covered a thousand times but i have not found a definte answer yet. Got ...
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
| The old hesitation after remap problem I know this problem has been covered a thousand times but i have not found a definte answer yet. Got my car back yesterday after a remap and have noticed a hestitation most noticable in forth and fifth. The car seems to hold back then surge then hold back again before returning to normal.This happens when i floor it and it picks up through the rev range, it has started since the remap. There are no fault codes and on the whole the car seems loads faster. There is just this slight problem. I would prefer to keep the car as close to standard as poss with regards to dv's, anyone with any ideas? Thanks
__________________ Regards Martin Turbo back blueflame exhaust |
| Re: The old hesitation after remap problem It could be a split diaphram on the dumpvalve. Its a good idea to upgrade to a bailey or forge type dump valve even on a standard car. The extra boost can make them fail on the way home after a remap. Im no expert but id change it anyway because its bound to fail soon anyway!
__________________ There's nothing like seeing feathers going in the opposite direction to the bird! ....................................... |
| Briskodian Join Date: Aug 2006 Location: Liverpool
| Re: The old hesitation after remap problem For info my standard DV has been on since remap earlier on in the year with no issues.
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| Re: The old hesitation after remap problem Cheers chaps, So is there a way to replace standard dv but with keeping genuine parts in mind? Also with my car having a 2.5" turbo back exhaust do you think this would affect the boost more than standard?
| Re: The old hesitation after remap problem There is no genuine part, only the same stuff you already have on there.
| | #6 | |
| Re: The old hesitation after remap problem Quote:
__________________ Regards Martin Turbo back blueflame exhaust | |
| | #7 | |
| Briskodian Join Date: Dec 2004 Location: South
VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com - Powered by vBulletin Hope this helps..... ![]()
__________________ cheeRS: | |
| Re: The old hesitation after remap problem cheers buddy
| Re: The old hesitation after remap problem Yes check you DV and replace e.g forge 007P. something i have on mines |
| | #10 |
| Re: The old hesitation after remap problem I can pretty much say it's not DV issues.......
| | #11 |
| Re: The old hesitation after remap problem What would you hint at the issue being mr superted?
| | #12 |
| Re: The old hesitation after remap problem er, its lag.
| | #13 |
| Re: The old hesitation after remap problem I don't think its turbo lag, because it accelerates, then slows, then goes again, almost as if it thinks i'm going to boot it, then decides i didn't want to after all. isn't Turbo lag the time spent waiting for the turbo to spool up after you boot it?
| | #14 |
| Re: The old hesitation after remap problem thats what i thought you were talking about.
| | #15 |
| Re: The old hesitation after remap problem Having searched and searched i think the general idea is you need to replace the standard Dv with an uprated one to cope with the excess pressure. Many mapping companies seem to recommend replacing the DV when you have the car remapped too as the standard cannot cope with the extra turbo pressure. Would it sound right that the old standard diaphragm Dv i have maybe fluttering/struggling a bit when i change gear causing the hesitation/surge?
| | #16 |
| Re: The old hesitation after remap problem Nope there is a big initial boost followed very quickly by a drop then back on boost.This all happens very quickly
| | #17 |
| Re: The old hesitation after remap problem I thought the hesitating thing was a before remap thing not after, it cured mine when it was done. And nothing else was replaced. |
| | #18 |
| Briskodian Join Date: Sep 2006 Location: York
| Re: The old hesitation after remap problem I have this same problem with my car and am not sure what it is. Mine isn't remapped though. It happens mainly in second gear say I put my foot down from 40 - 70 mph the turbo kicks in then seems to backs off about 2-3 times it all happens very quickly
__________________ Octavia vRS Mk1 55 Plate Corrida Red Blueflame turbo back exhaust 200 cell Cat, Carbonio C.A.I, Forge T.I.P, Forge Diverter Valve, Forge/Samco Hoses, N75-J Valve, Toyo Proxes TR1's and remap soon to come |
| | #19 |
| Briskodian Join Date: Apr 2006 Location: fife
| Re: The old hesitation after remap problem i had the same fault after my octy vrs was remapped,i already had an uprated dv on mine,i have done away with my n249 valve,its still connected electrically to keep ecu happy,but i have re routed vacum pipes to bypass,its not cured the hesistation completely but its loads better,plus the dv reacts a lot quicker,people will tell u not to bypass it,with the n249 in place the ecu has the option if it senses too much boost to open the dv will on throttle,but it can cause the problems ur having. |
| | #20 |
| Re: The old hesitation after remap problem Have a look here, this issue has been covered on US MKV and MKIV forums and the link here is for a fuel pump upgrade. In my opinion it is this that is causing the issue here, especially after remap. My opinion for what it is worth. BSH is now taking pre orders on the Autotech Fuel Pump - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
| | #21 | |
| Silver bullet Join Date: May 2003 Location: Planet Earth......
Or it might be an intermittent fault with your coil packs. What DV are you using? If standard it could just be that - that is fooked and causing the problem.
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() | |
| | #22 |
| Briskodian Join Date: Jun 2007 Location: Cornwall
| Re: The old hesitation after remap problem I've had mine for a while too. I'm tempted to just replace the n75 valve and dv and see if it sorts it. Then again that's £200 chucking away. I've got a stratmosphere DV in at the moment thats new .. but it only started happened a while after that was installed. It's annoying ![]() |
| | #23 | |
| | #24 | |
| Briskodian Join Date: Feb 2007 Location: Devon
you can get a new n75 valve for £35.00, and a standard dv is not much more, if i was you id go back to a standard dv if your car is not remapped.
__________________ Black octy mk1 VRS... with some mods. Last edited by gmaster; 11-11-2007 at 19:08. Reason: . | |
| | #25 | |
Mine happens when you change up gear,its as if something wasn't reacting properly to the change in turbo pressure.
