This is a discussion on only drivers door unlock with my fob 54 octavia 1.9tdi within the Octavia I forums, part of the Skoda Model Discussion Area category; When I press the unlock button on my keyfob only the drivers door unlock I have to unlock it with ...
| Briskodian Join Date: Dec 2007
| only drivers door unlock with my fob 54 octavia 1.9tdi When I press the unlock button on my keyfob only the drivers door unlock I have to unlock it with the button inside. Been working fine upto now and still locks ok on the fob. any ideas? |
| Briskodian Join Date: Mar 2005 Location: Upper Ramsbottom
| Re: only drivers door unlock with my fob 54 octavia 1.9tdi Mine is set so I have to press it once to open the drivers door, and twice in quick succession to open all doors. Have you tried doing that? I think you can change it to be the other way round with VagCom, or a dealer could do it.
__________________ The future's bright The future's mellow Now with a little zest of Washbrook added |
| Re: only drivers door unlock with my fob 54 octavia 1.9tdi Had the car over a year and its been fine. Only recently started playing up. |
| Briskodian Join Date: May 2006 Location: Nottingham, J26 M1
| Re: only drivers door unlock with my fob 54 octavia 1.9tdi It sounds like it's in selective locking mode. Have it scanned and have it coded to not be in selective locking. I also set mine to auto lock on the move and auto unlock when you turn it off and remove the key out of the ignition. A scan will reveal if there are any faults. Greg. |
| Octavia 1.9tdi Blocked Driver Door | gppera | Octavia II | 0 | 23-11-2007 22:37 |
| Octavia 1.9tdi 2001y Driver Door Blocked | gppera | Octavia II | 1 | 23-11-2007 22:34 |
| Drivers door closed on Octavia | stingwi | Octavia I | 6 | 28-10-2007 20:27 |
| Removing Octavia Drivers door trim? | howard_cooke | Octavia I | 12 | 01-06-2007 08:22 |
