Orange Brake light on the dash HELP!
This is a discussion on Orange Brake light on the dash HELP! within the Octavia I forums, part of the Skoda Model Discussion Area category; Had my pads changed last weekend and now this light has appeared on the dash.....anyone have any ideas what it ...
Old 04-09-2008, 09:13   #1
Zero's Avatar
Had my pads changed last weekend and now this light has appeared on the dash.....anyone have any ideas what it means? i know it's something to do with the brakes but what?
Any help before i have to drive home on the motorway would be much appreciated!
Thanks
Zero is offline
Old 04-09-2008, 09:26   #2
mbames's Avatar
Re: Orange Brake light on the dash HELP!
That is the front break wear indicator. Are you sure the pads were changed last weekend?!
iirc, the indicator is only on the nearside, so it might be worth it is connected properly.
mbames is offline
Old 04-09-2008, 09:30   #3
Zero's Avatar
Yeah, i know they were done because i work for the garage on the weekends and i got one of the blokes to change them for me whist i was off doing something else. I even saw the old pads hehe, i suppose the next question is what do i need to do to sort it? Where is Lumox when you need him!
Zero is offline
Old 04-09-2008, 10:04   #4
mbames's Avatar
I would start by checking to see if the cable from the pads has been connected to the wear indicator lead. iirc, they would by completing the circuit, so it is possible the new pads which were fitted did not have the suitable lead, and thus the socket from the car side of the loom has been left dangling, and has got wet due to the recent rain and is thus reporting the pads are worn.
Can you make a visual check of the pads to ensure they are all ok - if so then I would not worry too much. I drove my car for another couple of k after the warning light came on, but I did check the pad depth in the mean time - it was just a case of finding the time to change the pads and disks which delayed me.
If your really worried (and I guess for peace of mind too), why not pop into a garage and get them checked - are any places doing the "free winter checks" yet?
mbames is offline
The Following User Says Thank You to mbames For This Useful Post:
Zero (04-09-2008)
Old 04-09-2008, 10:06   #5
Zero's Avatar
Thanks bud, I'll be working there on Sat so as long as i know it can wait until then i can chill!
Zero is offline
Old 04-09-2008, 10:11   #6
mbames's Avatar
drive it carefully and check your brakes still feel normal.... if in doubt then get it checked :-)
I drove my ex gf's car once to take the dogs for a walk somewhere (rather than putting them in my clean octy), and when I braked I heard a horrible racket.... the pads had worn out all the friction material and it was breaking using pad backing on the disks..... nice. Funnily enough the gf had not reported any problems with the car! Maybe she was hoping I was going to kill myself!
mbames is offline
Old 04-09-2008, 10:46   #7
Zero's Avatar
well i braked hard and they worked, there still very new! Where is the sensor? is there just one on the front or on the back as well?
thanks
Zero is offline
Old 04-09-2008, 12:25   #8
KenONeill's Avatar
I think there's just a PWI on the LHF pad. The rears don't do much more than provide a handbrake function anyway, given that under hard braking the dynamic weight distribution can move to something like 90% front 1 or 2 up with no boot load.
KenONeill is offline
Old 04-09-2008, 12:55   #9
vRS_Si's Avatar
Hey Nick,
Which pads did you replace them with?
I run Ferodo DS2500's which don't have the slot in them to plug in the brake pad wear indicator.
You can make the circuit so that the light doesn't show or simply ignore it.
My brake pad light is lit and has been for the last 2 years or so
I know the pads aren't worn so I can live with it.
There is a way to turn the light off using Vag-Com but I've never been able to work out how!
vRS
Mirror polished 9*18" Mercedes Alloys, APR FMIC, ABD TIP & CAI, Powder coated inlet manifold, Jabba Re-map, Blueflame/Pipewerx exhaust, Forge DV, KW v3 coilovers, Neuspeed ARB, S3 strut braces, bonnet lifters, Autostyl rear spoiler, Milotec rear diffuser & bumper grills, side rubbing strips removed, front and rear rubbing strips smoothed and colour coded, scuttle pannel colour coded, chrome grill colour coded, mk2 vRS badge, de-locked, tints, mk4 aero wipers.
vRS_Si is offline
Old 04-09-2008, 12:59   #10
Why So Serious
fatty5000's Avatar
http://briskoda.net/technical-guides...via-mk1/50061/
Here you go
fatty5000 is offline
The Following User Says Thank You to fatty5000 For This Useful Post:
vRS_Si (04-09-2008)
Old 04-09-2008, 13:32   #11
Zero's Avatar
Thanks lads, i shall have a quick nose later but leave it till Sat when i'm in the garage.
Zero is offline
Old 04-09-2008, 15:09   #12
mbames's Avatar
a paperclip might function well here.... a proper blue-peter bodge
mbames is offline
Old 04-09-2008, 15:41   #13
Zero's Avatar
nothing wrong with blue peter
Zero is offline
Old 04-09-2008, 20:59   #14
vRS_Si's Avatar
Originally Posted by fatty5000 View Post
Perfect, thanks!
vRS
vRS_Si is offline
Similar Threads
vRS orange oil light won't go out twonks Octavia I 8 23-06-2008 18:05
Orange Oil Light cheezemonkhai Octavia II 7 18-10-2007 14:49
Orange warning light too :o Quinten Octavia I 38 27-05-2006 19:34
Disc Brake Dash Light.... Pythix Octavia I 5 06-06-2005 18:37
Orange warning light memoryman2 Maintenance & Performance 7 03-06-2004 20:35
