39,459 Members 1,489,969 Posts
Plastic under engine cover falling off
This is a discussion on Plastic under engine cover falling off within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi, I have Skoda Octavia 1.9sdi and the plastic cover that sits underneath the engine is falling off. Half of ...
Old 03-09-2008, 23:55   #1
Members Car:
Hi,
Half of it has cracked and actually come off so it is sagging in the middle and scraping across the floor.
I want to take it off but want to check it is not essential and that it won't matter if i don't have one.
Will it pass an MOT without the cover?
Thanks for reading.
tedda222 is offline
Old 04-09-2008, 06:58   #2
Lex Dysia's Avatar
Members Car: Skoda Octavia VRS 2002
Re: Plastic under engine cover falling off
You can safely remove it, its only there to help keep your engine a little cleaner and muffle noise I think. Mine did the same and it is now off the car. Others on here have done the same
Upper & Lower S3 Strut braces-Forge FMDV006 DV-PiperX panel filter-Whiteline adjustable rear arb-Superpro Dogbone, Control arm & Front ARB bushes-LCR Splitter-Milotec Grilles-Golf MK4 Aero wipers-KVW100-Cruise Control-Parking Sensors-18" RS8 Alloys-N75H-Revo Stage 1-TO DO: Turbo back exhaust-Koni FSD and H&R springs (5 Days to go)-Seat & Door Card Leather retrim and a respray.
http://briskoda.net/images/vbseo_skin_1.0/logo.gif
Lex Dysia is offline
The Following User Says Thank You to Lex Dysia For This Useful Post:
tedda222 (04-09-2008)
Old 04-09-2008, 07:15   #3
New to Posting
NickHubbard's Avatar
Members Car: Octavia vRS Mk1
Yes, I had the same problem and removed the cover. It went through an MOT without a problem. The cover reduces engine noise like Lex says and might make the car a little more aerodynamic down below.
A friend pointed out that the cover can be counter productive. If you have an oil leak above the cover, the oil will absorb into the cover rather than leaving tell tale signs in your parking spot. Not a reason to go and take the cover off, but something to be aware of.
NickHubbard is offline
The Following User Says Thank You to NickHubbard For This Useful Post:
Old 04-09-2008, 08:13   #4
soviet's Avatar
Originally Posted by tedda222 View Post
Hi,
Thanks for reading.
Hi tedda222,
I think that it will be good to have this in place, as it maybe protects engine sump here, from flying stones that are being picked up by the road wheels. This will stop the crack or hole in sump casings. May be you should think about getting the replacement from a scrap store.
Does any one else on the forum here, think this way?
Soviet
soviet is offline
The Following User Says Thank You to soviet For This Useful Post:
Old 04-09-2008, 09:28   #5
mbames's Avatar
My TDi undertray gets the comment "large untray prevents inspection from underneath" or something like that.
The bonus of keeping the undertray on is that it *might* catch the aircon clutch when it falls off
mbames is offline
The Following User Says Thank You to mbames For This Useful Post:
Old 04-09-2008, 11:44   #6
cheezemonkhai's Avatar
Members Car:
Do the clutch bolt up with some threadlock then
The undertray also helps with aerodynamics so will improve fuel consumption at higher speeds due to reduced drag. Probably nothing massive, but something noticeable.
cheezemonkhai is offline
The Following User Says Thank You to cheezemonkhai For This Useful Post:
Old 04-09-2008, 12:22   #7
KenONeill's Avatar
Members Car: Octavia TDi110
As you describe it Tedda, your car (specifically) won't pass an MOT "as is", but would if you removed the undertray, or replaced it. I think a new one is under £100.
KenONeill is offline
The Following User Says Thank You to KenONeill For This Useful Post:
Similar Threads
Plastic Cover Under Engine Bat. Octavia I 18 06-06-2008 15:36
Fabia plastic engine cover charca0 Maintenance & Performance 1 03-07-2004 22:01
Fabia plastic engine cover again ! Bellflower Maintenance & Performance 7 24-11-2003 22:50
Plastic engine cover. richardsonij Maintenance & Performance 7 25-04-2003 08:35
