This is a discussion on Porsche 944 brakes on octy? within the Octavia I forums, part of the Skoda Model Discussion Area category; Just found a set of 4 callipers and disks from a 944 in the store room and was wondering if ...
| Briskodian Join Date: Nov 2005 Location: derbyshire
| Porsche 944 brakes on octy? Just found a set of 4 callipers and disks from a 944 in the store room and was wondering if anyone has any experience of fitting these to an octy 4x4? I was planning on going for the 312 upgrade from golf turbo but these will be considerably cheaper So will they fit or not!Cheers |
| Briskodian Join Date: Nov 2003 Location: Walsall, West Midlands
| Re: Porsche 944 brakes on octy? cant answer, but one of the techs that work for a tuners might be able to help you... i'd have thought if the PCD of the bolts on the disks are the same as the hub on the car then you'll be half way there, you'll more than likely need some sort of carrier for the calipers making up though. i know APR do a Porsche brake kit for the octy vRS, i wouldnt have thought the fittings would be much different from the vRS and the 4x4.
__________________ Sea Grey Mondeo Titanium X |
| Briskodian Join Date: Jan 2003 Location: Winchester
| Re: Porsche 944 brakes on octy? Agree with Nigel, PCD is the first thing to check to see it the discs can be used, I would guess the callipers will be useable even if you need new discs e-mail Ian Godney ian@godspeedbrakes.co.uk He will be the man to help to manufacture new carriers etc & bespoke discs if required, all he does is Brakes & if anyone can make them fit he will & hes not ridiculously expensive. The hardest thing is normally getting hold of him He built the brakes for my 4x4
__________________ Speed is an addiction for which thankfully there is no cure Last edited by Stuart_J; 04-01-2006 at 12:56. |
| Briskodian Join Date: Aug 2005 Location: Middle East
| Re: Porsche 944 brakes on octy? Are they the mono-block capilers from an S2/Turbo or are they the sliding ones from a standard 944. If they are the sliding ones then I doubt you'd see any benefit. In fact the brakes would be worse I think because the 944 is a bit lighter than an Octavia. To fit the mono blocks would require some sort of adaptor because they have mounting holes in different places I think.
__________________ "New" 2002 Octavia vRS WRC 51/100 De-Stickered (Thankfully) Currently at 8000Kms on the clock Mods: Wheels painted dark grey to hide the brake dust Heat reflective window tint. Cool in all respects and my drivers seat is starting to fray already..... |
| Re: Porsche 944 brakes on octy? cheers for the info guys, I am not sure which they are, will go and have a look and see exactly what they are, I havent seen them just been told they are there! will get back to you when I find them! Cheers |
| Octy brakes | HongKongPhooey | Maintenance & Performance | 16 | 06-01-2005 22:39 |
| Octy vRS brakes on a furby? | devonutopia | Maintenance & Performance | 26 | 03-12-2003 16:07 |
| Noisy Brakes vRS Octy | usico | Maintenance & Performance | 6 | 05-11-2003 13:11 |
