39,459 Members 1,489,969 Posts
question about hot engine start
This is a discussion on question about hot engine start within the Octavia I forums, part of the Skoda Model Discussion Area category; Im owner of octavia 1.9 tdi.Here in Slovenia everybody tell me , that I have problem with software.In Slovenia can ...
Old 19-12-2007, 21:02   #1
Members Car:
Im owner of octavia 1.9 tdi.Here in Slovenia everybody tell me , that I have problem with software.In Slovenia can repaire problem with start engine and it cost 125€.So, who know, is the problem with software or is another thing to repaire.
francš is offline
Old 19-12-2007, 21:15   #2
ECUless
fordfan's Avatar
Members Car:
Re: question about hot engine start
I have seen them with a hot start problem. If it starts properly with the engine coolant temperature sensor (ECT) disconnected it is likely to be a fault with the engine control unit (ECU) - which in the UK is lot more than 125 euros. I have seen two work arounds for this:
The first is to wire the the ECT wire to the ECU through a switch, when you want to start it from hot use the switch to break the circuit and switch it back when the engine is running.
The second is to use a 5 pin relay instead of the switch. Wire it through the starter solenoid wire so that when the starter operates the ECT circuit breaks.
You could check also the injection pump timing and the valve on top of the fuel filter.
fordfan is offline
Similar Threads
Diesel hot start - more news! Mr Music Favorit, Felicia, Fun and Forman 4 13-08-2007 13:12
Diesel hot start problem Mr Music Favorit, Felicia, Fun and Forman 4 27-07-2007 22:35
Hot felcia wont start? cymrubach Maintenance & Performance 16 19-06-2007 08:18
Tdi 90 hot start problem solved!! Pass it around. nickrees Octavia I 0 22-03-2007 11:41
Will not start when hot Help Please smudge Fabia I 10 19-11-2006 22:39
