This is a discussion on Rattle & clatter - advice please. within the Octavia I forums, part of the Skoda Model Discussion Area category; As I mentoned, I have a rattle & clatter from my rear nearside caliper on the vRS. I have had ...
| Briskodian Join Date: Feb 2006 Location: Scarborough
| As I mentoned, I have a rattle & clatter from my rear nearside caliper on the vRS. I have had the wheel off and think it is the inside pad moving around when the car is moving, ( I did hit a particularly bad pot hole on Friday). Apply the brakes and the sound stops. Two questions: 1. Is it a simple job to sort? i.e. Can a complete novice like myself sort it? 2. As the car is under warranty, but the dealer is a 40 mile round trip, would sorting it myself (or getting another independent garage to sort it) cause warranty issues? The dealer also charges £10 for a courtesy car, there's the fuel for a 40 mile trip and the hassle of getting the car there during the week. If an independent garage could do it for me for a few quid, then it would work out as cheap as using the dealer. Your thoughts please. ![]()
__________________ |
| Briskodian Join Date: Jul 2006 Location: South Birmingham
| Use this for reference, i used it to do my brakes. Brake pad and rotor replacement - Passat World Forums Are both tension springs still in place ?
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() |
| Good question. Probably not, I'm assuming the jolt caused the spring to come off/loosen itself. Mind you, this is the first car where this has happened, I wouldn't have thought a Skoda would be phased by such a thing. Even my rusty old Fiats were a bit better than this... It may be a warranty job anyway looking at the process involved I think. I don't want to mess around and bodge the job up and have to go to Skoda with the problem worse than it already is. Thanks for the advice though.
