This is a discussion on Rear brake guide pins? within the Octavia I forums, part of the Skoda Model Discussion Area category; I was going to start changing the rear discs and pads tomorrow but read in the Haynes Manual about using ...
| Briskodian Join Date: Feb 2005 Location: central Scotland
| I was going to start changing the rear discs and pads tomorrow but read in the Haynes Manual about using new guide pin bolts. Is this strictly necessary? Are there any other bolts that should be replaced? cheers |
| mmm, I have to say that I never change the bolts! But when I did the GFs felicia last year, the new pads cme with guide bolts in the box. I had a problem with a sticky slider (which I discovered a few weeks ago - not fixed it yet), but I popped to my local bolt shop (eurofasteners) where I purchased 4 allen-key headed bolts for a massive 80p (total) |
| Are the bolts in question coated with thread lock (or use Nylock nuts)? If so then I would replace them. |
| Briskodian Join Date: May 2005 Location: Cleator Moor
| Came up a while back and Ross stated that the main reason for replacment is that the Bolts come with threadlock already on. Hence you can reuse the bolts as long as you put some new threadlock on. They are only tourqed to a very low value so bolt strength is fine. |
| Nice one guys - I checked the price of them and they were a very expensive 37p plus VAT so just bought 4. I have never worked on a car before - looking forward to getting stuck in. |
| £1.74 for 4, or less than a tube of decent quality threadlock IME. |
| | #7 | |
| I have VAG COM Join Date: Jul 2006 Location: South Birmingham
| Quote:
I have since replaced discs and pads all round on my Octy vRS and i am very please with my efforts.
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() | |
| Why me ? Join Date: Oct 2005 Location: North Yorkshire
| The pads I bought to replace the rears came with new bolts..... with them having threadlock on I used the new ones instead of putting thr old ones back in. |
| This was very helpful, Same as the octy: Brake pad and rotor replacement - Passat World Forums
