This is a discussion on Rear tyres only lasting 5k what should I try? within the Octavia I forums, part of the Skoda Model Discussion Area category; I currently run Goodyear F1 GSD-3's on my octy in 225/40/18 and while I'm happy reasonably happy with the wear ...
| Briskodian Join Date: Jun 2004 Location: West Yorkshire
Members Car: Audi S8 Thanks: 41
| Rear tyres only lasting 5k what should I try? I currently run Goodyear F1 GSD-3's on my octy in 225/40/18 and while I'm happy reasonably happy with the wear rate on the fronts the rears lasting only 5k is something I'm not happy about. I was thinking of trying the Pirelli P-Zero Nero's next time I need a set of 4 as they get raved about on here. Can anyone comment on how they wear compared to the GSD-3's. Also is it likely to improve wear if I go for a wider tread, say 235? Does anyone have any other recommendations? I hear Michelin pilot sport's wear well but also don't give as much grip as GSD-3's. I've also tried Toyo T1-R's (on the Ibiza) and whilst they are good tyre's and life was comparable to the GSD-3's grip wasn't 'quite' as good.
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport |
| Don't talk, drive! Join Date: Feb 2003 Location: The B roads of Britain
Members Car: 1983 Porsche 928S / 1972 MGB GT Thanks: 17
| Re: Rear tyres only lasting 5k what should I try? Moved to Octavia |
| Briskodian Join Date: Oct 2006 Location: Isle of Wight
Members Car: Skoda Fabia vRS Thanks: 0
| Re: Rear tyres only lasting 5k what should I try? How are the tyres wearing? On the edges / evenly / down the middle / etc. Have you got the dealership to check the rear brakes for binding? I have had the problem on my old car with the nearside front tyre scrubbing out after 5-6k and got it renewed under warranty because the caliper was faulty. I'm sure the VAG 4x4 sytem only puts the power to the rear wheels when the fronts loose traction!?!? So are you a "little" lead foot out of every junction? ![]()
__________________ Was - Red Fabia vRS Now - Milano Civic Type R - and loving it! Last edited by ncarring; 16-11-2006 at 12:06. Reason: Fix quote markers |
| | #4 | |
| Re: Rear tyres only lasting 5k what should I try? Quote:
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport | |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
Members Car: Merc E class & SLK Thanks: 19
| Re: Rear tyres only lasting 5k what should I try? Pilot Exalto PE2 or Pilot Sports last reasonably well and seem to grip OK too. You'll get about 8-10 out of the Neros.
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| | #6 | |
Also does anyone know the criterea for needing the 'Extra Load' versions? My GSD-3's have always been the XL version but wasn't sure if I actually need it or not.
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport Last edited by EddyH; 16-11-2006 at 11:00. | |
| Re: Rear tyres only lasting 5k what should I try? It's more to do with weight than any thing else. By being able to cope with extra weight, they have stiffer sidewalls. GSD3s have relativekly stiff sidewalls in comparison to Neros.
| Re: Rear tyres only lasting 5k what should I try? I'm struggling to find info on what weight the standard Nero's and XL Nero's are designed for, any ideas?
| Briskodian | Re: Rear tyres only lasting 5k what should I try? The Pilot Exalto 2 (PE2) have been on my car for about 25k and still going fine with over half the grip left. They are IMHO a nice grippy tyre too, especially in the wet. HTH
| | #10 |
| Re: Rear tyres only lasting 5k what should I try? The load index is a numerical code, which corresponds to the maximum load a tyre can carry at the speed indicated by its speed symbol, under specific service conditions. A tyre's load multiplied by 2 must cover the gross single axle load of your vehicle. It goes up in 20kg increments eg. 92 = 630 kg 93 = 650 kg 94 = 670 kg 95 = 690 kg
| | #11 |
| Briskodian Join Date: Jan 2003 Location: Winchester
| Re: Rear tyres only lasting 5k what should I try? I find when I "use" the car hard I get a lot of rear brake dust which I understand is partially generated by the ESP using the rear brakes to stabilise the car. I know youve changed your haldex controller but how much more power goes to the back ? Also what mileage are you getting out of the front tyres ??
__________________ Speed is an addiction for which thankfully there is no cure |
| | #12 |
| Re: Rear tyres only lasting 5k what should I try? The results for the Michelin Exalto PE2's on tyretest.com seem very good.
| | #13 | |
I don't think there's more power going to the rear wheels than with a standard controller it's just more often. It anticapates slip so if I put my foot down hard it automatically sends power to the rear, as I do this quite often the rears see alot of action. I get at least 10k from the fronts maybe more.
| | #14 | |
I cant understand why the rears only last 1/2 the time of the fronts. The fronts tend to get more drive & certainly work a lot harder under braking Clutching at straws but is the rear tracking way out, if both wheels are toeing in or out too much the tyres would tend to scrub. Im guessing if it was even you might not notice it. Sure is a strange one, you dont do loads of handbrake turns do you ??
__________________ Speed is an addiction for which thankfully there is no cure | |
| | #15 | |
I don't do any handbrake turns, I do sometimes drift it a bit on roundabouts but not excessively.
| | #16 |
Members Car: Octavia TDi110 Thanks: 65
| Re: Rear tyres only lasting 5k what should I try? I'm thinking that you maybe need a 4-wheel alignment check, esp if the car's slammed and/or on different width/offset/rolling radius to standard. |
| | #17 |
| Re: Rear tyres only lasting 5k what should I try? It's not slammed, rolling radius is very close to standard, 4-wheel alignment was done about 1-2 month ago.
| | #18 |
| Re: Rear tyres only lasting 5k what should I try? The rears can be adjusted although not a lot, Powerstation always do mine & there is a certain amount of "tapping stick" involved
