39,459 Members 1,489,963 Posts
rear washer!!!
This is a discussion on rear washer!!! within the Octavia I forums, part of the Skoda Model Discussion Area category; if this has been asked before i apologise... i cant seem to get water out of my rear washer. the ...
Old 15-03-2008, 18:51   #1
mr_weed's Avatar
Members Car:
rear washer!!!
i cant seem to get water out of my rear washer. the motor makes a healthy whirring noise but not water!
is there a trick im missing to getting the h2o supply back? its stopped working when my washer bottle ran dry
mr_weed is offline
Old 15-03-2008, 19:06   #2
Members Car: mk1 octavia vrs
Re: rear washer!!!
Hi is yours a hatchback? mine did the same and it was the washer tube had come disconnected in the boot, remove the cd changer and the panel trim on n/s in boot area and check connection near electrical plugs, if it is this washer tube then check the electrical connectors as water gets sprayed over them and they will need to be dried out,hope this helps!
timmytailpipe is offline
The Following User Says Thank You to timmytailpipe For This Useful Post:
mr_weed (15-03-2008)
Old 15-03-2008, 19:14   #3
mr_weed's Avatar
Members Car:
Re: rear washer!!!
yes it is a hatch. ill have a look tomorrow, too dark n cold now! thanks again
mr_weed is offline
Old 15-03-2008, 19:18   #4
Silver bullet
Steevie Wonder's Avatar
Re: rear washer!!!
Don't bother taking the multichanger out, just pull the trim out above it.
I had to do mine today, took less than 30 seconds!!
Steve
The silver bulletJabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.
Steevie Wonder is offline
The Following User Says Thank You to Steevie Wonder For This Useful Post:
Old 15-03-2008, 20:53   #5
Need more power
martziniuk's Avatar
Members Car: octavia VRS
Re: rear washer!!!
I would disconnect the pipe at the rear jet first and try it, as the jets get blocked. Worth checking for water here first before you have to dismantle the car,its possible that you have not blown a pipe off.
Regards Martin
Turbo back blueflame exhaust ,Forge 007p Dump valve, Ramair filter, Prosport boost gauge, Autobahn88 TIP, Ecu Evolution Remap, FMIC
martziniuk is offline
The Following User Says Thank You to martziniuk For This Useful Post:
Old 16-03-2008, 19:07   #6
Members Car: Fabia VRS
Re: rear washer!!!
Hi,
My rear washer has now failed, the garage have told me the valve has failed, and can not be sourced as a spare and has to be purchased along with a new pump, cost £90, are they having a laugh, I guess I need to start packing a water bottle and a squeegie...
GingerDan is offline
Old 16-03-2008, 20:12   #7
Need more power
martziniuk's Avatar
Re: rear washer!!!
or just go to a scrap yard,octavias are getting quite common.
Regards Martin
Old 24-04-2008, 16:12   #8
Re: rear washer!!!
Hi guys,
I have a similar problem.
My washer failed a while ago as the tube disconnected from the wiper behind the tailgate cover. I re connected it and its been fine for a while. Recently, although the wiper works and the tube is attached, no water comes out.
From what I can see the tube goes up to the top of the tailgate and into a short rubber section connecting to the roof of the car body.
What is supposed to be behind the lining near the CD changer? Will I find another tube there???
Are there any other places to check the tube?
Does it go along the nearside or offside of the car to the bonnet??
Thanks,
Stu
stuu3270 is offline
Old 24-04-2008, 16:26   #9
phillip's Avatar
Members Car: Octavia vRS
Re: rear washer!!!
As Mart says above...disconnect the pipe from the wiper arm first then try it...if water comes out then it is the jet that is blocked, and you won't need to look any further .
PROTECTING THE PEOPLE OF THIS WORLD FROM THE SCUMBAGS OF THE UNIVERSE !!!
phillip is offline
Similar Threads
Rear Washer metfab1 Fabia I 0 08-02-2008 15:03
Rear window washer colonel-shoe Fabia I 17 12-03-2007 22:33
Rear washer fault LES CATTO Fabia I 1 04-03-2007 23:48
Rear windscreen washer seandolan Octavia I 6 05-03-2006 20:12
Rear Washer Phillb Fabia I 8 04-12-2004 21:15
