This is a discussion on Rotate or not? Tyres that is... within the Octavia I forums, part of the Skoda Model Discussion Area category; I've got Conti Sport Contact 2's on my Octy TDI, fitted as a set of four. The fronts are now ...
| Briskodian | Rotate or not? Tyres that is... I've got Conti Sport Contact 2's on my Octy TDI, fitted as a set of four. The fronts are now at about 1/2 - 1/3 tread left. The rears are probably 1/3 worn. Should I rotate them front to rear? I guess, if I don't, then I will be replacing the fronts soon. ££ If I do, I will be replacing a complete set again later. ££££ I do about 2k - 3K a month, so tyres are a regular expense.
__________________ 'No more beer!' (unless it's GF) |
| Crossdresser Join Date: Apr 2003 Location: fast lane
Members Car: Citroen C-Crosser 2.2HDI Thanks: 25
| Re: Rotate or not? Tyres that is... I always change in pairs. The fronts are obviously the ones that go quickest, so when they need changing I put the new tyres on the rear, and the old rears to the front. |
| | #3 | |
| NOW @ PEUGEOT Join Date: Nov 2003 Location: Bicester,Oxfordshire
Members Car: 2 x octavia vrs 03&01 Thanks: 32
| Re: Rotate or not? Tyres that is... Quote:
Strange that.....I thought " I " did Phil
__________________ 1)RED ONE, FEW MODS; AND A HEALTHY 237bhp 2)GONE BUT NOT FORGOTTEN, 2ND OWNER OF THE BLACK BEAST, GOD WHAT A HOOT ![]() LACK OF PLANNING ON YOUR BEHALF DOES NOT CONSTITUTE AN EMERGENCY ON MINE | |
| | #4 | |
![]() We did it... ![]() | |
Members Car: Octavia TDi110 Thanks: 65
| Re: Rotate or not? Tyres that is... Only when the car's moving! ![]() Seriously, it's up to you, and I'd suggest making the decision based on whether you want to stick with the Contis, or fit something else. If you're happy with the Contis I'd leave it, and get the rears brought forward when replacing the fronts. If you want shot soonest safely, swap them now, and they should all wear out about the same time. |
| 200 laps....... Join Date: Dec 2003 Location: Essex
Members Car: Octavia vRS,Renault Clio Trophy 237/500 Thanks: 0
| Re: Rotate or not? Tyres that is... Always put new tyres on the rear.
__________________ Alex Skoda Octavia vRS-Awaiting Mike at Impossible to sort out STILL RenaultSport Megane R26 Ultra Blue Number 21 Honda CBR600Fi |
Members Car: Fiat Panda Thanks: 15
| Re: Rotate or not? Tyres that is... I tend to not bother rotating tyres anymore and just replace them per axle, although I'm sure at some point they'll all wear out together and I'll be needing to get 4 done. I just put the new tyres on whichever axle the old ones came off ![]() Chris
| Briskodian Join Date: Jul 2005 Location: UK - SouthEast
Members Car: Audi A3 1.8T Sport 1999 Thanks: 2
| Re: Rotate or not? Tyres that is... I always tended to slap new tyres on the axle they came off, but just read this: http://www.tirerack.com/tires/tirete....jsp?techid=52 |
| Briskodian | Re: Rotate or not? Tyres that is... Very interesting. I guess I need to convince the tyre place to swap the backs to the fronts and the new ones on the rear.
| | #10 |
| Briskodian | Re: Rotate or not? Tyres that is... I think my rears will wear out first ![]() |
| | #11 | |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
Members Car: Merc E class & SLK Thanks: 19
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() | |
| | #12 | |
Seriously, I've seen film of one of these tests, and starting off by using a Vauxhall (Opel in the rest of Europe) Corsa (and yes I have driven one of these; works pool car or hire car) without ABS, and then only succeeding in getting it to spin by pushing hard into a corner and braking hard tells me lots about the "test" agenda, none of it good. Also you notice how they talk about how the newer tyres have a higher resistance to aquaplaning (and get the name of that wrong), but ignore how the front tyres actually dry out the road for the rears. | |
