Scraping or twanging sound.
This is a discussion on Scraping or twanging sound. within the Octavia I forums, part of the Skoda Model Discussion Area category; TDi110 on 78_000 ish. Fitted with new rear discs and pads about 2 weeks back. Now has a noise, sounds ...
Old 08-05-2008, 09:40   #1
KenONeill's Avatar
Default Scraping or twanging sound.
Now has a noise, sounds like a scrape from inside the car, or more like a twang from outside, seeming to come from the LH rear corner.
Noise is related to road speed, and sometimes goes away when, or as a result of, braking.
I'm thinking that maybe a pad, clip or shim is mis-aligned, or if there's a locating pin for the HB function it's not picking up correctly.
My only other theory for now is that there's damage inside the tyre.
Any other thoughts? (esp from the mechanics)
KenONeill is offline
Old 08-05-2008, 10:33   #2
phillip's Avatar
Default Re: Scraping or twanging sound.
It could be the tin back-plate rubbing on the disc...jack it up, remove the wheel and spin the disc, if you can hear it, then just bend the back plate away from the disc in the relevant area .
PROTECTING THE PEOPLE OF THIS WORLD FROM THE SCUMBAGS OF THE UNIVERSE !!!
phillip is offline
Old 08-05-2008, 11:03   #3
KenONeill's Avatar
Nice thought, but we tried that last night (well with the wheel still attached).
We also had a good poke about the underbody, and there's nothing obvious rubbing anywhere, and the exhaust is correctly hung.
Old 08-05-2008, 11:17   #4
cheezemonkhai's Avatar
Take the pads out, lube up the sliders and then put it all back together.
Do the pads have the chamfered edges?
Regarding the tyre damage, try the spare?
cheezemonkhai is offline
The Following User Says Thank You to cheezemonkhai For This Useful Post:
KenONeill (08-05-2008)
Old 08-05-2008, 11:37   #5
KenONeill's Avatar
Pads were fitted with Copaslip (just visible on edges of backplates.
Probably pattern parts, so I doubt is if the chamfer's an OEM thing.
I honestly think the problem's more likely the brake, cos it sometimes stops completely when or after you brake. That said, if it is the tyre, I'll be talking to Toyo, because the rears don't get big hits compared with the fronts (caused by having to drive over rough patches when hard on brakes).
Old 08-05-2008, 11:51   #6
Bodge's Avatar
what about the brake pad retaining springs that are fitted into the brake carrier?
they are more like shims than springs to me, but thats what skoda call them!
suppose one could be damaged/misaligned. they look like they would cause the sound your describing if they were to rub on the disc.
they are quite flimsy.
only way to know for sure is to whip off the calliper i guess...
K&N panel, Forge FMCL007P, ECS mag plug, Kumho KU31's up front, Avon ZV3's rear, Philips X-treme Power headlights, Philips SilverVision indicator bulbs, Valeo Silencio X.TRM wiper blades, Ripspeed black 12cm aerial, Mintex Xtreme pads all round, Alpine CDE-9880R, Castrol Edge 5W-30, Always 97-100RON fuel, and alot of TLC!
Bodge is offline
Old 08-05-2008, 11:56   #7
If it's a scrape/knocking noise I'd be tempted to get some fine sand paper and just take off the leading edge by a couple of mm on the pad and see if that stops it.
Otherwise I take it the disk is the correct one and isn't contacting the carrier in any way.
Old 08-05-2008, 12:23   #8
KenONeill's Avatar
That's the sort of way I was thinking, but I was specifically trying to not suggest that as the cause until someone else said it.
Old 08-05-2008, 12:26   #9
KenONeill's Avatar
Perhaps I should have said that it happens going backwards as well as forwards then. Also (and a mechanic at the garage who fitted the brakes has already agreed this) it's very definite that the sound comes from one corner and not the other.
Old 08-05-2008, 15:05   #10
KenONeill's Avatar
Thanks guys. Panic over; turns out it was a stone trapped under the dust shield!
Old 08-05-2008, 19:03   #11
Get out the way
Taxi 219's Avatar
thats a good cheap result
Car now: 56 Octavia MK2 1.9TDi Ambiente
Previous: 06 Octavia Mk1 1.9TDi Classic with + pack
Sadly missed: 97 Nissan Primera 2.0TDi SLX
Taxi 219 is online now
